front diff mounting bushing
Old Jun 18, 2008 | 09:07 AM
Andy&Kelly's Avatar
Andy&Kelly
Default front diff mounting bushing
Hi Guys. Find myself spending more time on the vette after work than with the wife.
Anyway, i'm installing the rear diff, and using poly front bushing in the front mount. If i put the bushing together without the diff, it moves around in the frame mount hole 1/8 inch side to side. Is this normal? I assume once its bolted to the rear crossmember and bolted to the front mount in the frame it won't really move?
Thanks in advance
Andy
Old Jun 18, 2008 | 09:48 AM
GTR1999's Avatar
GTR1999
you're better off with the rubber type for that application. Some of the poly's are not the correct size.
