new member needs advice
Old Jun 22, 2008 | 12:57 AM
79_L82's Avatar
79_L82
Default new member needs advice
I am a new member to this site and I have recently purchased a 1979 corvette L82. I bought the car for 7700 and believe it or not it was parked in a barn for some time now. I cant believe what great condition it is in. It was restored in 97 the third owner never worked on it AT ALL. So all the maintainence work is left for me but i have some questions. I AM NOT AT ALL A MECHANIC. so here it goes i have a leak on the bottom of the transmission where the filter it is the gasket. Someone told me that if i tried to replace it myself i could run into some major problems. A friend told me he replaced one in his truck after completion the transmission stuck and wouldnt move. Please help it is leaking big time. should i take it to someone or try it myself.
Old Jun 22, 2008 | 06:13 AM
RunningMan373's Avatar
RunningMan373
It's a dam* messy job, there are better jobs to start out with. I would take it to a trans shop-- 70 bucks???
The pan is full of fluid, with no drain hole, you have to have a big flat catch pan, and you'll still get fluid all over the place, have to put the car on jack stands. the Mechaninc has a lift, and a catch bottle w/a funnel, done in 20 minutes.
Old Jun 22, 2008 | 07:45 AM
wnmech's Avatar
wnmech
79 L82 welcome to the forum. You may not be a mechanic now but i guarantee you by the time you get the car the way you want it you will be a mechanic. These old vettes always need TLC. Changing the transmission gasket is not a hard job but like running man said it is kind of messyand probably cheaper to have it done buy a shop. Just have a big pan under the oil pan and remove enough bolts to where the back side of the oil pan comes down enough to drainthe oil into the bucket.
Old Jun 22, 2008 | 08:30 AM
SIXFOOTER's Avatar
SIXFOOTER
Welcome aboard and congrats on the Vette!
Its not a hard job at all, but it is messy. Take out all the bolts except 1 on the front corner and 1 on the back. Loosen the front one a bit and then remove the back one. That will allow you to drop the back of the pan to partially drain it. then take out the front bolt. Scrape off the gasket and clean the pan and swap in a new filter. The torq on the pan bolts is 10 ft lbs.
Old Jun 22, 2008 | 08:36 AM
GDaina's Avatar
GDaina
replace the filter in it's original position, else you will have problems shifting like your friend.
Old Jun 22, 2008 | 09:59 AM
marshrat99's Avatar
marshrat99
Welcome. I agree with everyone above. The tranny leak is messy but a simple fix. I also agree that the 79 will need some TLC to make it dependable. When I bought mine several years ago, it was a true survivor car, 65K miles and nothing had ever been maintained. I spent several hours replacing 25+year old parts to get it where it was a dependable DD. However, I wasn't interested in restoration, just having a dependable and slightly hopped up ride. My advise it that the 79 is relatively simple to work on and would be a great opportunity for you to develop some mechanical skills. If you've got the patience and garage space, time to start collecting some tools and enjoy. If it were me, start with a good set of jack stands, floor jack and a set of Craftsman 1/2" drive sockets and wrenchs. Definitely buy the AIM and repair manual. Take your time with each piece of work that you encounter and you'll have some fun and pride of knowing that you've learned something and have probably done a better job in the repair that you'd get at the dealer's shop.
Old Jun 22, 2008 | 10:06 AM
79_L82's Avatar
79_L82
Thank you for the advice. I think I might let a shop handle this one. Im am going to fix the brakes today and hopefully next week take it to the shop. Thank you for the nice welcoming. This forum seems to have some of the friendliest people. Thank you
Old Jun 22, 2008 | 10:08 AM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
If you change it yourself, be sure to put the proper amount of fresh fluid back in. Usually, this is a little over 4 quarts. I generally put about 3 1/2 quarts in and then start it up, get it up to operating temp and then check the fluid level (on level ground and tranny in park) and top off as necessary. I've seen more than one thread here where someone changes the fluid, installs just 2 quarts and then can't figure out why the tranny won't shift properly.
Old Jun 22, 2008 | 10:10 AM
...Roger...'s Avatar
...Roger...
If you do this yourself dont forget to flatten the pan back out where the bolts went through the pan or it will leak when your done.
Old Jun 22, 2008 | 10:16 AM
Jud Chapin's Avatar
Jud Chapin
BTW, welcome to the Forum. Why don't you take a few minutes and fill out the profile info. This can help Forum members help you.
Old Jun 23, 2008 | 12:40 AM
69elky's Avatar
69elky
Can not give you any more ifomation then what you have received,I am an orginal owner 79 L82 and it is a great car so welcome to the Corvette Family and have fun with your car.
Old Jun 23, 2008 | 02:50 AM
jdunne's Avatar
jdunne
Strongly suggest you drain and replace oil + filter.....and also completely drain and replace the brake fluid....sitting for 11 years must mean it needs replacing...john
Old Jun 23, 2008 | 06:20 AM
69small block's Avatar
69small block
Default congrats
welcome to the forum and vette ownership If you cam get an GM shop manual for your car an assembly manual is also helpfull there both still availible chilton are sometimes quite vauge on details that you need to know well anyway good luck with car amd again welcome
Old Jun 23, 2008 | 12:17 PM
7T1vette's Avatar
7T1vette
Changing trans fluid, filter, and gasket is something that only needs to be done every 30-50K miles. Take it to a reputable oil change/transmission shop. Let them do it. You'll never need to do it again [at least, as long as you will own the car].
Old Jun 24, 2008 | 01:46 AM
79_L82's Avatar
79_L82
I have a chiltons book the previous owner gave me and I also have the original owners manual, reciept for the car when it came off the lot, (Had 4 miles on it) and all reciepts of the restoration. I agree that this project will be too large for me at the moment. I wanted to change the brakes and fluid but, my wife, well has her ways. This weekend though,i will get this all done cause shes working. I changed the oil when i first got the car and i do believe they cranked it every now and then. I will fill out my profile as well. ha ha kinda new to the computer to.
Old Jun 24, 2008 | 11:39 PM
jrl77's Avatar
jrl77
Welcome to the club, as previously stated before long you will be a mechanic or very much in debt, When I did my leaky tran. pan I replaced it with one that has a drain. Reason being some old oil will still be in the unit and may be contaminated, I ran the new fluid for approx. 50 milles and then changed it again. maybe overkill but now it's nice and clean and smells good
Old Jun 24, 2008 | 11:53 PM
feb18blacksunday's Avatar
feb18blacksunday
From: Boone NC home of 3peat National Champs ASU Mountaineers
St. Jude Contributor
Welcome to the forum. Lots of good peeps and info here, to another 79 owner.
To new member needs advice
Old Jun 25, 2008 | 09:31 PM
my 76 ray's Avatar
my 76 ray
Make sure the leak isn't from the seal on the shifter shaft. It can look like it's from the seal on the pan. It wasn't until I had the pan all cleaned up from replacing the seal on the pan that I could tell the leak was from the shifter shaft.
Old Jun 25, 2008 | 10:24 PM
82crossfirevette's Avatar
82crossfirevette
Welcome aboard. Some great advice and helpful people here. Before you know it you'll be a C3 Mechanic. Enjoy!
I was thinking that while reading down the thread. Pick up new valve cover gaskets and reseal and lube the rear diff while you're at it.
So true.
Old Jun 27, 2008 | 12:10 AM
79_L82's Avatar
79_L82
Well from what i could tell it is at the pan but your right it could possibly be from another source. When I take it to the trans shop I will inspect the car myself on there lift. They might also have the same opinion. I am willing to do whatever it takes to make this car run, look, and drive perfectly. My wife on the other hand well she calls it our new pit, money pit.
