Exhaust smoke
Old Jun 22, 2008 | 11:40 AM
wcdknows's Avatar
wcdknows
Default Exhaust smoke
Hey guys..I'm hoping someone can help me with this problem. I have a 70 L46 with 82k miles. If I accelerate hard from a standstill blue smoke comes out of the exhaust. It doesn't happen when leaving normally. Also, if run hard, I'll notice smoke coming from the left manifold...thoughts??
Old Jun 22, 2008 | 11:45 AM
glassman74's Avatar
glassman74
Blue smoke is a sign of oil. Black is gas. glassman74
Old Jun 22, 2008 | 12:21 PM
Averystingray75's Avatar
Averystingray75
yeah usually burning oil, if you can rev your engine parked, and go behind and see oif it smells a little like burning oil, also sometimes (usually white smoke) you can burn anti-freze is your engine running hot?
is it running out of oil frequently?
Old Jun 22, 2008 | 01:31 PM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
...and white is water.
Old Jun 23, 2008 | 11:42 AM
wcdknows's Avatar
wcdknows
Would you recommend engine rebuild kit or new engine? Are the 350/300 HP engines just as strong as the stock 350/350's?
Old Jun 23, 2008 | 11:55 AM
ghoastrider1's Avatar
ghoastrider1
if it does it on start-up,chances are its the valve seals,easily replaced at a very modest price. Just under hard accel..make me wonder if the rings are about at the stage to need replacement. Do a compression test,static and the other.That,above all else,will tell you the state of you engine innards. Yep,gray or blue smoke is always oil burning.By the way,if it just did it in decellaration mode, high vacum exist,so oil would be sucked past worn rings and /or valve seals.
Old Jun 23, 2008 | 12:01 PM
wcdknows's Avatar
wcdknows
By the way, I'm also noticing some dieseling ...
To Exhaust smoke
