Engine Vacuum
Old Jun 23, 2008 | 08:37 AM
Guru_4_hire's Avatar
Guru_4_hire
Cruise-In IV Veteran
Cruise-In V Veteran
Default Engine Vacuum
How much vacuum should I be getting with a 73 L82.
The previous owner had a single plane intake on it, that I finally got around to replacing. I remember it pulled 15-16lbs of vacuum. I put on an edelbrock EPS intake and now I am getting like 12lbs on the ported vacuum line.
I will check the manifold vacuum port when I get home from work.
Old Jun 23, 2008 | 09:16 AM
SH-60B's Avatar
SH-60B
Manifold vac is what you want to check. 12 inches of vac might not get you power assist on the brakes. Isn't the EPS a dual plane? Is the idle the same as before?
Old Jun 23, 2008 | 12:12 PM
7T1vette's Avatar
7T1vette
Changing the intake manifold only won't alter the vacuum level (unless your intake manifold gaskets aren't sealing properly). You likely have a vacuum leak somewhere.
Old Jun 23, 2008 | 01:31 PM
Guru_4_hire
Cruise-In V Veteran
What should the manifold vacuum be?
Old Jun 23, 2008 | 01:52 PM
lars's Avatar
lars
Ported vacuum doesn't mean anything. You need to measure direct manifold vacuum. For info, vacuum is measured in inches of Mercury (inHg) and not in lbs.
Lars
Old Jun 23, 2008 | 02:06 PM
Guru_4_hire
Cruise-In V Veteran
Yep, your right, my bad.
To Engine Vacuum
