Idle problems
Old Jun 24, 2008 | 09:58 PM
lt1350's Avatar
lt1350
Cruising
Default Idle problems
My vette wont idle when its warm. It konks out at stop signs unless I keep my on the gas. The problem seems to be getting worse with time. It idles fine when cold.
Its a 71 LT1 with wih a Holly carb. Any ideas?
thanks
Old Jun 24, 2008 | 10:24 PM
Durango_Boy's Avatar
Durango_Boy
Sounds like your choke is not adjusted properly anymore. Have a look at the choke. Make sure it's closed when cold, and open when hot.
Old Jun 25, 2008 | 05:48 AM
Matt Gruber's Avatar
Matt Gruber
soak the metering block in carb cleaner
Old Jun 25, 2008 | 06:40 AM
Bangkok Dean's Avatar
Bangkok Dean
Sounds like vapor lock. Are you running a return line from the fuel pump to the tank? The return line keeps the fuel flowing and cool so there is no boiling in the line. I even run an in tank fuel pump and a return line from the carb to the tank. Over here the traffic lights are long and temps are always over 95* during the days. With out the above the idle will drop to stall at lights.
Old Jun 25, 2008 | 07:42 AM
sxr6's Avatar
sxr6
Bangkok: if the car was vapour locking, it wouldn't start again, trust me I know
LT1-350: have you tried the simplest solution first, adjust you idle speed?
Old Jun 25, 2008 | 11:36 AM
Bangkok Dean
In my experience the vapor lock can be in the fuel line along with the carb and will restart when pumping cool gas back up threw the fuel lines. My comments were not a guess but from months of looking for the problem and finally fixing it. Now if his choke is staying closed his idle will be higher as it will not kick down. I have had that happen forgetting to close the hand choke it idled high but ran supper rich.
The OP says the problem on hot days is at stopping so I assume his idle is OK when moving. Been there done that.
Old Jun 25, 2008 | 11:55 AM
Matt Gruber
thanks
i didn't see any hot in there.
posters are notorious for poorly describing things, however
Old Jun 25, 2008 | 12:15 PM
Bangkok Dean
I hear you but in my case the engine never went over 190*
In any case I hope he is able to find his problem and not take months like it took me.
Old Jun 25, 2008 | 02:06 PM
sxr6's Avatar
sxr6
Not saying your wrong but my experience is a vapour lock & your car won't star!
If car is moving I sincerely doubt it's idleing
He said "won't idle when warm", I assume he meant when warmed up & choke kicked off.
Old Jun 25, 2008 | 03:20 PM
lars's Avatar
lars
If idle quality is bad or erratic on a hot Holley, check for a warped metering block. A non-flat block will allow fuel crossover between idle and main circuit metering passages, and will cause the problems you describe. Just lay a straight edge across the block after you remove it from the carb and verify that it is flat within .005" in every direction and on both sides. If it's warped, just get a new one from Holley - a very affordable fix that will make a huge difference in idle quality.
Lars
Old Jun 25, 2008 | 08:46 PM
my 76 ray's Avatar
my 76 ray
It could also be a vacuum leak.
Old Jun 25, 2008 | 11:09 PM
lt1350's Avatar
lt1350
Cruising
To clairfy: Engine won't idle when it has warmed up. Choke - as it should - gradually opens as engine warms. The engine will continue to idle when warm until the first time I rev it. After I rev the engine - and the choke kicks off - the engine won't idle.
The car will restart after cutting out - but only if I keep my foot on the gas giving it some revs (it will idle at 700 to 750 - maybe as low as 650 while giving it gas). When I stop giving it revs it konks back out.
I will definitly check level of metering block. If level I will clean it.
thanks to all - this is a really big help
Old Jun 26, 2008 | 08:43 AM
sxr6's Avatar
sxr6
Again I would check the idle screw!
How many have fought for hrs only to discover it was the little things?
Old Jun 26, 2008 | 08:12 PM
lt1350's Avatar
lt1350
Cruising
Problem solved. You were right sxr6 - all it needed was to adjust the idle screw.
Old Jun 27, 2008 | 03:20 PM
sxr6's Avatar
sxr6
I'm a genius
To Idle problems
