Headlight relays
So my headlights don't work. I replaced all the lines and so there aren't any more leaks (in the lines.) The tank leaks (previous front end accident) so I just bypassed it. However, the lights still don't budge. So I pulled the relays and if I pull vacuum on the metal port the valve moves forward and back like it should. However, if I pull vacuum on the yellow, it leaks even if I plug up all the other holes. Is there something that I'm doing wrong? I was just surprised that both would be broken exactly the same.....and thus I'm thinking I must be doing something wrong.
When I just hold the yellow vacuum line up to either the red or green lines on the headlights they actuate right away, no hesitation or anything.
Sidenote... I expect I need to replace the relays, so did anyone convert to fixed headlights? If you don't need your relays, shoot me a PM.
