Miles per gallon
Old Jun 28, 2008 | 10:41 AM
johnrem46's Avatar
johnrem46
Default Miles per gallon
Just got my 77 on the road for the first time. The car has been sitting many years before I got it. Here is my problem I am getting about 8 miles to the gallon. Is this normal?? Where should I start to try and improve the gas milage? The Carburator looks like it could use an update. I know there are problems with the choke. I have done nothing to the engine except plugs and wires.
Old Jun 28, 2008 | 10:51 AM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
8 miles per gallon sounds low even with all town driving. I think my '76 gets around 15 on the highway and probably about 12 in town. I would give it a thorough tune up including new distributor cap and air and fuel filters. If the choke is on a lot, that will make the engine burn quite rich and drop your mileage. It should be adjusted properly. I'd also change all fluids and rad. hoses if you haven't already done so.
Old Jun 28, 2008 | 11:16 AM
johnrem46's Avatar
johnrem46
Thanks.. I have changed the fluids and hoses. The choke is all rusted. Do you think a new carb would help?
Old Jun 28, 2008 | 11:19 AM
Jud Chapin's Avatar
Jud Chapin
I would contact Lars, a Q-jet expert who has helped many forum members.
http://forums.corvetteforum.com/show...highlight=lars
Old Jun 28, 2008 | 11:32 AM
80_vette's Avatar
80_vette
well my 80 vette does about that...8 miles a gallon but my engine isn't stock...It came with 195HP stock but I'm up to 325HP right now.Oh well,they are fun to drive
Old Jun 28, 2008 | 11:46 AM
a1sensei's Avatar
a1sensei
My '81 got about 15 city/18 highway when I got it stock (185hp). Now I get 18 city and 23 highway with around 375 hp. Efficiency = power + economy!
Fix your carb (no, don't replace it), check the exhaust manifolds for leaks (usually sounds like a ticking noise), replace your cap, plugs and wires and set your timing. God bless, Sensei
Old Jun 28, 2008 | 12:05 PM
ptroxx's Avatar
ptroxx
From: Henderson Nv-Rohnert Park/Sonoma C o. ca/born in NY Rockaway Beach.
I Have a 77 and im getting about 10city and about 15 hwy when im not trying to keep up with the c5 and c6's on our cruises.
i would bet that a rebuild on the carb would show a big diff
Old Jun 28, 2008 | 12:11 PM
johnrem46's Avatar
johnrem46
When you say fix the carb? are you suggesting I get a rebuild kit and go at it? I was just checking and the idle is high, if I lower the idle the car stalls it is either high or nothing. Also looked in the carb and it seems gas is dripping from in between the jets at the back part of the opening. I hope I am explaining it correctly.
Old Jun 28, 2008 | 12:29 PM
Matt Gruber's Avatar
Matt Gruber
have lars do the carb,
get a good true dual exhaust
Old Jun 28, 2008 | 12:34 PM
johnrem46's Avatar
johnrem46
The car does have a true dual exhaust.. Do I just eMail him or does he have a web site?
I assume he does these rebuilds as a business????
Old Jun 28, 2008 | 12:39 PM
zwede's Avatar
zwede
Check the vacuum advance on the distributor. I bet it is seized! Also your mechanical advance (weights) can freeze.
No timing advance = Poor mileage + sluggish engine.
Old Jun 28, 2008 | 06:49 PM
wattac2's Avatar
wattac2
As I drive along in my 427 BB/Holley I watch the fuel gauge drop like the second hand on the clock, just backwards.
Old Jun 28, 2008 | 06:57 PM
400hp427vette's Avatar
400hp427vette
St. Jude Donor '09
with the tri-power I'm getting around 18 when I drive it nice, It's like a BB 2-barrel until you driv it hard.
Old Jun 29, 2008 | 06:25 AM
johnrem46's Avatar
johnrem46
Thank you all for you suggestions.. I have contacted Lars and will do a rebuild. Can't say that this will solve all my issues but it is a atart. Thanks again.
Old Jun 29, 2008 | 07:43 AM
Jud Chapin's Avatar
Jud Chapin
One step at a time and you'll get there. Lars can help you with your situation in addition to the carb.
Old Jun 29, 2008 | 09:47 AM
Avette4me's Avatar
Avette4me
Cruise-In VIII Veteran
I'm getting about 25 MPG out of mine.
14 on the highway and 11 in town.
Old Jun 29, 2008 | 09:53 AM
Jud Chapin's Avatar
Jud Chapin
Me too.
Old Jun 29, 2008 | 12:50 PM
lars's Avatar
lars
If the car has been sitting for a while and is getting poor mileage, I can tell you with almost complete certainty that your ignition system needs to be repaired - fixing the carb alone won't do it for you. Your vacuum advance is almost certainly ruptured, and your centrifugal advance is either gummed up or rusted up. You need to fix your distributor first by freeing up the advance mechanism and installing a new vacuum advance. Then, set your timing to 36 degrees total. After that, do the carb to finish it off.
Lars
To Miles per gallon
