Seatback hinges
Old Jul 4, 2008 | 11:16 PM
68FireBird's Avatar
68FireBird
Default Seatback hinges
So I decided to jump in and start working on putting on my new seat covers on my 76. Right off the bat I've hit a snag.
I can't get the chrome seatback hinge bolts off to seperate the seat.
Is there a trick to it. Should I just cut them off?
Old Jul 5, 2008 | 09:40 AM
LYLE's Avatar
LYLE
Some have a jam nut on the back. Some are just very tight or rusted. PB blaster may help. I use a tool that when you hit it with a hammer the screwdriver end spins to take out the screw and it come with a large phillips bit. Harbor Frieght should have it in ametal box about 6"X3"X1" thick.
Old Jul 5, 2008 | 11:20 AM
68FireBird's Avatar
68FireBird
I sprayed it with the PB blaster last night.
That tool sounds like a good one.
Old Jul 5, 2008 | 12:58 PM
'75's Avatar
'75
That tool is called an Impact driver and usually comes in 3/8" drive and has several bits. Another trick that may work is to use the biggest philips head screwdriver that will fit the screw, get a death grip on it and turn it counter clockwise and use a hammer to hit the end of the handle as you turn. If it won't turn, spray on more PB then hit it harder.
Old Jul 5, 2008 | 07:51 PM
68FireBird's Avatar
68FireBird
I went and picked up an impact driver. I didn't think it was going to work at first but it did after some more PB and several wacks with the hammer.
I've got the passenger seat striped, sanded and painted. The seat bottom is broken. Has anyone had any experience witht the seat repair plate?
Thanks for the help!
Old Jul 5, 2008 | 08:41 PM
LYLE's Avatar
LYLE
I have just welded them up and added metal to fix cracks. The most important step before installing the covers is to reassemble the seats with the bumpers and make sure they line up as most bottoms are bent up.
Old Jul 5, 2008 | 09:33 PM
croaker's Avatar
croaker
I put in a piece of alumium to reinforce the rear part
Old Jul 5, 2008 | 11:44 PM
Peterbuilt's Avatar
Peterbuilt
I bought the repair plates, 7 years later there still good. PG.
Old Jul 7, 2008 | 02:42 PM
68FireBird's Avatar
68FireBird
I ordered the seat repair plates today.
I went ahead and installed the foam and cover on the passenger seat back last night. I just couldn't wait to get started. It looks great! I hear the bottoms are tougher to do, I guess I'll find out after I get the frames in order.
To Seatback hinges
