Where does this connect?
Old Jul 9, 2008 | 01:00 PM
rayluka's Avatar
rayluka
Default Where does this connect?
1976 L-48 350
I have a vacuum connection and dont know where it goes. Any ideas. This is the front of the Q-jet
Old Jul 9, 2008 | 01:07 PM
PhyscoVette's Avatar
PhyscoVette
PVC check
Old Jul 9, 2008 | 01:49 PM
Douglas Mariani's Avatar
Douglas Mariani
GM Cert Corvette Tech
Pro Mechanic
It looks to me its the vacuum connection for the air cleaner
Old Jul 9, 2008 | 02:11 PM
antongonza's Avatar
antongonza
I believe this connects to pvc valve on driver sid e valve cover .On my 78 it also T's off to a canister under brake booster I am not sure what canister is for . Hope this helps.
Old Jul 9, 2008 | 02:56 PM
...Roger...'s Avatar
...Roger...
It looks like you have some plugs in the thermostat housing.I believe tha port went to a thermo valve for either the heat riser or the EGR.
edit-hmmm no I'm not so sure on second look I think maybe antongonza might have the answer.
Old Jul 9, 2008 | 03:08 PM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
It goes to the thermostat housing.
Old Jul 9, 2008 | 03:51 PM
7T1vette's Avatar
7T1vette
PCV line is the large one in the center of the baseplate. If you don't hook up the "open" one you asked about, put a cap on it so that you don't lose vacuum.
Old Jul 9, 2008 | 04:22 PM
rayluka's Avatar
rayluka
Thanks, It seems to be running rough. I'll check all the ideas Ive been given.
Old Jul 9, 2008 | 04:50 PM
Project80's Avatar
Project80
What you need is the Emission Hose Routing diagram for that year. I still have a sticker under the hood of my 80 and I guess yours is missing. 7T1vette is correct, you need to cap that until you find out what goes there.
Old Jul 9, 2008 | 05:32 PM
bmotojoe's Avatar
bmotojoe
Not sure if the 76 year model had the canister located on drivers side near firewall to help purge fumes from the fuel tank. That’s where this fitting is on my 77 carburetor.
(Not seen in photo) Above the fuel filter housing there should be a accessory port, this is where the vacuum supply line would go to the thermostat housing if thermo switches were installed.
Old Jul 9, 2008 | 07:43 PM
'75's Avatar
'75
On my 75 it goes to the canister under the master cylinder.
Old Jul 10, 2008 | 11:47 PM
68FireBird's Avatar
68FireBird
It goes to the canister under the master cylinder on my 76 as well.
Old Jul 11, 2008 | 08:26 PM
rayluka's Avatar
rayluka
Sure enough...charcoal canister. Got the idle nice. Now if I can find out why it hall ***** but when it hits second the thing bogs out. Maybe a rebuild is in the future for the carb.
To Where does this connect?
