Plug wire choice
Old Jul 10, 2008 | 10:25 PM
TACatfish#64's Avatar
TACatfish#64
Default Plug wire choice
In my 69 300hp 350 I've got a stock dist with a pertronix kit that the previous owner put in. I am running the stock ignition shielding. What are your opinions on the best plug wires to run?
Thanks for the opinions.
Old Jul 10, 2008 | 10:52 PM
randommj's Avatar
randommj
I just use the cut-to-length wires that Auto Zone had
Miles
Old Jul 11, 2008 | 07:04 AM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
I like OEM brands, Delco in this case. Stay away from off brands as the quality is generally not there. It's a lot of work to install these the way the factory did so you want something that is going to last a long time.
Old Jul 11, 2008 | 11:06 AM
jim2527's Avatar
jim2527
I agree. Wires can be installed without removing the motormounts.....
IMO its not to difficult if you work from above and below....
http://forums.corvetteforum.com/show...ght=plug+wires
Old Jul 11, 2008 | 12:56 PM
zwede's Avatar
zwede
I like the Taylor cut-to-fit wires. Good quality. You would need a proper ignition terminal tool (about $50) but it would let you make the wires the perfect length for routing/looks. The pre-cut sets are usually too long.
Old Jul 11, 2008 | 02:36 PM
RonR80's Avatar
RonR80
St. Jude Donor '09
I installed the Bosch custom fit , guarenteed for life whatever that means! But they fit real good .On this side I could not get any Delcos. But the seem to be fine ,Ron
Old Jul 11, 2008 | 08:47 PM
7T1vette's Avatar
7T1vette
You didn't mention whether the ignition coil is stock or Pertronix upgrade coil. Buy wires appropriate for the voltage your coil is providing. Spending big money on 'purty' wires is a waste of money.
To Plug wire choice
