rotor run out
Old Jul 9, 2008 | 08:36 PM
hgm's Avatar
hgm
Default rotor run out
I am checking rotor run out trying to solve a fading brake pedal. Back is +/- .001 and +/- .004, front is is +/- .006 and +/- .003. Couple of questions:
1) I read the spec is +/- .002 is that correct?
2) Should I try to get to a tighter tolerance.
Old Jul 9, 2008 | 08:59 PM
Oldguard 7's Avatar
Oldguard 7
The General states runout at .005. So one of your rotors are out of specs. However other members such as GTR1999, state one should get run out to .002 to resolve the spongy pedal issue. I replaced all my rotors and replaced the RF and LR calipers, installed speed bleeders, and bled the brake system with a Motive pressure bleeder and the spongy pedal is gone. Some members will say this is a band-aid approach to fixing the spongy pedal problem. Although my spongy pedal is solved, I am converting to the C5 brakes, both front and rear. Because checking rotor runout, shimming rotors, checking runout again can be a pita.
Old Jul 9, 2008 | 10:13 PM
Mike Ward's Avatar
Mike Ward
+/- .006 = .012 total. Waaaaaaaaaaaaay out of spec.
Old Jul 9, 2008 | 10:43 PM
SIXFOOTER's Avatar
SIXFOOTER
Dial it in less than .002 on each corner with spacers under the rotors.
Old Jul 9, 2008 | 10:54 PM
stpman's Avatar
stpman
Spent 2 hrs today doing both rear rotors I got 1 to .002 and the other is at .0025 have to make another shim and check again.
Steve
Old Jul 10, 2008 | 03:30 PM
Oldguard 7's Avatar
Oldguard 7
checking for for runout .that is such a pita. 2 hours just to change rotors. It shouldn't take 2 hours replace rotors.
I changed rotors on all four corners and replaced the LR and RF calipers as they were leaking. I installed speed bleeders and used the motive brake bleeder to bleed them and my pedal is firm as ever. I did not check for runout. For all the brake problems concerning rotor runout threads I read on the forum, I must have gotten lucky. I am putting C5 brakes on both the front and rear brakes.
Old Jul 10, 2008 | 04:51 PM
...Roger...'s Avatar
...Roger...
Speaking of shimming rotors.When you guys use the shimming method and get it down to .002 have you checked after a month or some really hard driving to see if it still reads .002 ?
Old Jul 10, 2008 | 05:56 PM
Oldguard 7's Avatar
Oldguard 7
Interesting point. I don't bother with it. I wonder if those who who swear by it do that.
Old Jul 10, 2008 | 06:20 PM
hgm's Avatar
hgm
Shim stock will be in tomorrow and I will work on it this weekend. That is a good point about where it is after it has been run for awhile. I just heard about using c-5 breaks. What is the advantage? What does it take?
Old Jul 10, 2008 | 10:58 PM
Oldguard 7's Avatar
Oldguard 7
Opinions vary. The C5 brake system is of a floating caliper design whereas runout occurs but it is not as critical because of the floating caliper design. VBP sells a C5 front brake kit. A few members have done this front brake conversion and have not reported any problems. I am doing both front and rear brakes as I have the necessary components to do so. I am having caliper mounting brackets fabricated for me. I also have C6 wheels because the C5 calipers are wider than the fixed C3 caliper.
Old Jul 11, 2008 | 10:23 AM
GTR1999's Avatar
GTR1999
I have checked my car and the runout has not changed since I bolted on and dialed in the rotors. Car stops on a dime. I'm happy with them.
Old Jul 11, 2008 | 01:09 PM
Green76's Avatar
Green76
Would it not be better to pull the two front hubs and press out the studs, then take the hubs to a machine shop and have the faces turned untill the hub are running true, that would end all future problems when replacing brake rotors........
I would think that brand new rotors are running true and paralell, since almost everting made today is manufactured on a CNC machine.
Old Jul 11, 2008 | 01:18 PM
stinger12's Avatar
stinger12
Almost all new rotors have runout to some extent. They aren't all parallel.
Old Aug 25, 2008 | 09:23 PM
rocco_73's Avatar
rocco_73
Any chance someone has pictures of the rotor run out repair process? I think my 73 has it real bad. I've done plenty of brake jobs on other cars, but have never had experience with this run out problem.
What are the shims you use made of?
Where do you measure for this?
On the rear wheels, if you need to spin the rotor to see how it rides in the caliper... I've tried this, but it's really tough to spin the back rotor even with the car in neutral due to the e Brakes....
I really am concerned about this condition on my car... the rear wheels are toed in really bad and I'm blowing through tires on the inside edge.
Thanks,
Roc
Old Aug 25, 2008 | 10:48 PM
7T3C3TTZ07's Avatar
7T3C3TTZ07
The photo is rotated 180 degrees for some reason. I use a dial indicator attached to a piece of iron, held to the steering knuckle with a Vise-Grip. I have the rotor held on with two nuts. I've heard that when shimming, it is good to have all the nuts on tight as the rotor can distort when all nuts are torqued down. I plan to do that next time.
The procedure is to mark the high spot (or low spot) and rotate the rotor on the hub around 180 degrees (i.e 144 or 216), then to see if it improves. Ultimately, indexing it in 72-degree increments to find the lowest runout. After that shim the low side with around 1/2 the thickness of the total runout. If that is correct, then one may wish to support the adjacent bolts with around 2/3rds of that thickness. There is a product sold at GM dealers called BrakeAlign that is a tapered ship that comes in various thicknesses. I have not tried it.
Old Aug 25, 2008 | 10:52 PM
bertmeister's Avatar
bertmeister
My front rotors have .005" runout. I put the VBP calipers on 3 years ago, bled the brakes, and have had no brake problems in the last 20,000 miles.
Old Aug 25, 2008 | 11:09 PM
45ACP's Avatar
45ACP
My rotors run .0005" TIR or less on all four corners and I will not accept a higher reading, but I'm a machinist and can pull off that sort of idiocy with relative ease.
To rotor run out
Old Aug 26, 2008 | 12:24 AM
Ironcross's Avatar
Ironcross
Default WTF...Dial indicators and Shims?.
Corvette brakes are the same as any other car. If your attempting to true up rotors that your just replacing pads on with rotors out of round, what that is telling you is to get the rotors machined. The fronts are super easy by chucking them up on the races. The rears are just as easy when finished with a FWD hub-less rotor adapter. Any quality auto parts can do the job. Good machines are a plus though. Any store with a 'Van Norman' drum and rotor lathe will make them dead nuts every time. Screwing around with dial indicators and 'shims' is a waste of time. We have cut hundreds of rotors for customers on every conceivable car. Also my service center did several brake jobs a week without a incident. And yes we do Vettes...
A previous reply mentioned that even new rotors can be out of round. He`s correct, we have to cut them too. So pulling them from a box, we always check them on the lathe to see if there true as a large percentage may not be. Time to us is money. If you cant do them right the first time, how the hell will you have time to do it a second time....
Old Aug 26, 2008 | 03:25 AM
RunningMan373's Avatar
RunningMan373
FYI, i used a unique solution with my 4 new rotors, took the 'Vette to the Chevey dealer and had them turn the rotors on the car, with one of the new 'bolt to hub' machines. Several hundred miles now,, no fade or air. just make sure when you get the car back, to remove each tire and spray a dot of paint on 1 lug, and rotor hole, to install them back correctly, if you ever remove them again. they will be true in the position they were turned in.
Old Aug 26, 2008 | 09:08 AM
pws69's Avatar
pws69
This is certainly what I would do if mine were out. Never have to worry about shims.
