Is that the advertised duration on this cam? Good grief that's much too long of a duration for 9.6:1.
I just looked it up and looks like your right. http://www.gmpartsdirect.com/results...umber=24502476
Ok so maybe it is timed in right. He could still benefit from advancing it some....maybe. Ultimately it needs to be a shorter duration cam. This must be a very old school cam for that slow of a ramp.
Not sure I'm doing this right because the numbers look crazy to me, but when I put in numbers to get a 9.6:1 SCR for a 320* cam with a 112 lsa (guessing that one) it comes up with a DCR of 5.82. Also gives me an intake valve closing angle of 92.5*. That sounds crazy late to me.
I'd say mystery solved. Thanks matt I hadn't bothered to look up the cam and made some bad assumptions. since I'm new to this I had no idea that a cam could be a 320* lash and have a 212@.050. Wow!
You'd have to kick up the SCR to around 12.5:1 to get the SCR up to something reasonable.
here, let me get that translated for you..... he bought the wrong cam.
Or, put even more specifically, he needs more motor to run that cam
I've said it before, everyone needs to, at least once, buy a cam from the bottom of the page and make it run - it'll teach you everything you need to know about motors (and really, in a good way).
When I first studied cams there was just total duration given and then they came out with this newfangled @.050 measurement. I thought any duration prior to .050 lift was irrelevant?
I wouldnt really think that 212\222 would be too much for 9.6 to 1.
LOL, that's not much help. Could you give me a bit more detail than that while summerizing what reelav8r said in more generic english?
high rpm motors needs lots of duration (time the valve is open) to fill the cylinder (pipe down pros, this is a grade school course, not post-doctoral).
The problem with long-open-times is it reduces the time the cylinder has with the valve closed (I know, duh), but what that does in real numbers is lower the compression. If you have a car with low compression (to begin with), putting that cam in the car would make it difficult to start, and it'd never idle because it just isn't developing enough compression for the resulting bang to make it run.
Ramp - how quickly the valve opens. Obviously, you can "fix" some of the issue listed above by opening the valve more for less time by increasing the ramp. Thus, and for example, you can flow 200 cfm into a cylinder either with a 220 duration and 1" lift and nearly and vertical ramp, or have less ramp and keep the valve open longer with 320 degrees of duration and 1/2" of lift. In the OPs case, the ramp is a low ramp, and long duration which makes the effective compression 5.82 - which would cause all sorts of driveability problems.
this, in no way refers to my just prior post...
it shouldn't be - that's nearly stock.... which to refer all the way back to what I said before - if the cam's too small, any gain with heads would be reduced by too small of a cam - and it's possible that the velocity would be so affected that putting better heads on a motor could actually make the motor perform worse.
REE
with the 320* intake duration, what is the DCR?
9.6 SCR. must be really low dcr. like what 5.5:1?
The cam is both too big(seat to seat) and too small 212 at 050.
XE262 would perk it up, with proper base gasket of course.
REE
You guys are all way off. GM rated their hydraulic cams @ .000 lift. Aftermarket are rated @ .004 or .006. Duration difference between .000 and .006 would be a lot because the lobe lift is transitioning right there. GM rated solids different yet at somewhat less than lash measurement but not .000. The L88 cams had an advertised intake duration of 354 but actual is somewhat under 300 at lash point. See here: http://cochise.uia.net/pkelley2/solidcams.html
Notice the drastic difference in duration at low lift but not so much once your up on the ramp.
Thanks for the explanation SuperBuickGuy, that helps.
Originally Posted by SuperBuickGuy
320 has to be a mistype.... betting 220
No, I think he's referring to the total duration which is 320 degrees rather than the duration at 50 thou (212/222) if I understand him correctly. Note the listing for the OP's cam:
What confuses me, is people used to give figures for total duration only then suddenly it was duration at 50 thou and I understood the reasoning to be that the valve hadn't moved at all with hudraulic lifters until 50 thou lobe lift therefore the total duration was irrelevant, only the duration at 50 thou mattered. If that's the case it wouldn't seem to me that 79vetter's cam has too much duration.
79Vetter, thanks for posting your dyno sheet.
I see the peak torque is at a relatively high 3500 rpm or so but the torque curve is broad and doesn't drop off that much in the 2000-2500 rpm range, so I still maintain that the performance 79Vetter is getting out of this Vortec/cam combination is about what one would expect and reasonably good given the parts used, i.e. relatively close in performance to the GM330HO (330 gross hp) crate motor he was more or less trying to clone
This what i was refering to. I didnt catch that the advertised duration was 320, it is in fact a crapy cam. If the op doesnt want to buy another cam, he could advance it 4 degrees to raise cylinder pressure and bring the rpm range down by 500 or so rpm, still not the off idle torque he's looking for but would run better or he could buy a descent cam, i say Grubers favorite would work well in this application.
This what i was refering to. I didnt catch that the advertised duration was 320, it is in fact a crapy cam. If the op doesnt want to buy another cam, he could advance it 4 degrees to raise cylinder pressure and bring the rpm range down by 500 or so rpm, still not the off idle torque he's looking for but would run better or he could buy a descent cam, i say grubbers favorite would work well in this application.
