On my pad it dont show post numbers. I see were he bought a new cam that was 212\220.
The cam was 320 total duration and 212/222 at 50 thou. Once again, it is my understanding that total duration is irrelevant as with hydraulic lifters the valve doesn't start to move until .050 lobe lift.
I think 79Vetter's cam is relatively well matched to his heads and he could get some minor improvements by fine tuning with a different cam but a different cam or advancing his existing one won't make significant differences with his heads, certainly not ones he can feel given that he couldn't feel the roughly 65 net horsepower increase from the vortec/cam changes. Making significant improvements over what he's got now will require well matched significantly bigger cam and bigger heads.
You guys are all way off. GM rated their hydraulic cams @ .000 lift. Aftermarket are rated @ .004 or .006. Duration difference between .000 and .006 would be a lot because the lobe lift is transitioning right there.
So what do you figure the lift might be at .006? 280,290 even 300?
A 280 @.006 might work but the others seem a bit long in the duration for 9.6:1.
Looking at the dyno it looks like the cam would benifit from some advance and maybe a 2000-2500 or better stall converter. The chart starts at 2000 rpm but if you were to interpolate the fall in HP and maybe torque,(but that slope were it first shows up on the chart might not be accurate), power would certainly be low for anything below 2000 rpm. It looks about right for a short cam as far at where it peaks (about 5250) and torque comes up by 2000 rpm and is farily flat. But it seems low on the torque overall. Is this the symptom of a low intensity short duration cam, wide lsa? Or is it poor flow somewhere? I'm gonna have to cognate on this one. Maybe like Matt says too tall and too short at the same time.
.006" stands fot .006" of lift, same as duration @ .050" is @ .050" lift.
I figured that. Once again, was I mislead all those years ago that only duration at .050" matters with hydraulic lifters as the valve hasn't started moving yet? In other words, what does it matter what duration is at .000" or .006"?
I would bet it is under 270 @ .006. I agree the cam is part of the issue. Low lift, slow ramp and as others have said too big of advertised and to small of duration @ .050. That said it has a slow, safe ramp and will likely run 100,000 miles. Matts favorite cam is a better match for this build. As I originally thought a lower rear gear would make a huge difference.
Duration @ .006 or 004 does matter for DCR purposes. You need between 7.5 and 8.5 dcr in a street engine to produce best power.
1. You can have a cam that has 280 duration @ .006 and 215 duration @ .050.
2. You can have a cam that has 268 duration @ .006 and 215 duration @ .050.
Both will work in the OP's build. Both will operate in the same rpm range. Effective compression or DCR will be much higher in cam # 2 where cam # 1 might have low enough DCR to reduce performance a lot. This could very well be the issue.
So, you're saying what I read back in the 80's - that only duration at .050 lift matters on a hydraulic lifter cam because the valve doesn't start moving until .050 - is wrong?
Yes. Valve starts moving as soon as the lifter hits the start of the ramp. Duration @ .050 will determine what RPM range the cam makes power in.
we don't know the .006" duration for the GM cam. it is 262 for the xe262.
a Cam Dr. would tell it. Or it could be checked with a degree wheel in an engine. I once had a turbo corvair that had crazy long stock duration, even longer than the 476. i checked it when rebuilding it. maybe 330-360, i forget exactly. long time ago. Anyway, the car was such a dog off the line, i sold it. and it was turbocharged! turbo-dog! isn't there a tv show turbo dogs?
GM is going to be way longer than compcams. This is how comp built their business, cams with shorter ramps, etc, make more power.
My guess, the 476 at .006 tappet lift is 280-295 and the valve is open .009, enough to stop it building compression at low rpm. so poor off idle torque.
there is a guy on speedtalk that says advancing the 962, and 151 6, yes 6, really helps. so i'd go 4-9 if it was convenient. BeeJay has a long ramp GM HotCam roller, i think he advanced it 9
Take a look at this dyno. Notice how flat the torque curve is like the op's torque curve. If you subtract 50hp for losses of the trannie you almost have the same torque. The Hp is lower across the board for the op but he is not running a roller extreme energy cam. http://www.compcams.com/v002/Pages/397/XR282HR-10.aspx
Looking at this page you'll notice a trend that all the high duration cams have very flat torque curves where as the shorter cams have more of a parabola to them. I'd say the ops cam has the torque profile of a 280+ cam with the HP range of a 260 cam, worst of both worlds http://www.compcams.com/Pages/401/dyno-sheets.aspx
If I were him I would start by advancing the timing 4* to 6* on this cam as long as he could determine that exhaust valve clearence would still be good. This at least would bring the torque up faster and not cost anything but time.
My .02 would be to try the timing sugestions and a 3:70 rear would greatly increase your seat of the pants feel, 4:11 if your not worried about highway cruising.
I had a 345 scout with a dual range transfer case.
i'd put it in low range in 4x4, and it would LEAP. Top speed was 60mph, but it got there FAST.
that is like a 6:1 rear.
I think the long GM ramps are early Torque Management. TM is used on new cars to cut back low rpm torque and reduce warranty claims. So they used the long ramps in c3's to prevent burning the tires at every stop. They even slighty cut down the divider in some cars to further reduce torque. I've also seen iron intakes with passages connecting the 2 planes. What do you think that was for? TM! Sneaky, Huh!?
The factory timing curve was also set up to reduce low RPM torque and reduce warrantee claims. The slow ramp does the same thing and also reduces cam wear, valvetrain issues and allows the use of weaker springs to further reduce long term wear.
let me get this straight, you're suggesting spending $1,500 to swap rear gears; a problem that could be solved with a $200 cam swap? Not to mention that with the higher numeric gear the car becomes harder to drive, wears parts out faster, and gets much worse mileage.... while I certainly understand the idea of laying out all the options - I wonder about at what point the answer is in the weeds....
60 mph in low range in a Scout.... ummm...
2.72 - 4.54 diff gears
low range 2.46
some math.
4500 rpm, 31" tire, 2.72 gears = 62 mph (never mind that a binder would come apart at 3500)
with 4.54 gears - same as above, that's 37 mph @ 4500
Are you certain it was 60 mph? perhaps with the short wheelbase it seemed like 60 but was really only 40?
but yes, in regards to the GM stuff - sneaky, very sneaky.
and yes, it appears I'm being a bit snarky this morning - mostly, I'm sorry about that
