Wiper door
Old Jul 24, 2008 | 08:14 PM
rcread's Avatar
rcread
Default Wiper door
So I'm driving down the road this morning in my '71, top down, minding my own business, when all of a sudden the wiper door pops up for no apparent reason. I got to work, shut the car off and pushed it back down. Then I started the car back up and it popped back up. Any suggestions as to where to start a diagnosis for my wayward wiper door?
Old Jul 24, 2008 | 08:19 PM
C3 Stroker's Avatar
C3 Stroker
Check first for a vacuum hose that may have come loose....
Old Jul 25, 2008 | 02:17 PM
rcread's Avatar
rcread
Checked. All vacuum hoses are secure.
Old Jul 25, 2008 | 02:26 PM
pws69's Avatar
pws69
On the passenger side, the wiper needs to press down on the vacuum switch to signal that the door can close. If the switch is worn, has moved, or is maladjusted (or the wipers are), the door will pop open as you have indicated.
Try pushing down on the passenger side wiper (car running) to see if the door will close. DO NOT do it with your fingers, you would be surprised how much force the door has!!
Old Jul 25, 2008 | 02:29 PM
mrvette's Avatar
mrvette
don't ask how I know this....personally.....
Old Jul 25, 2008 | 02:31 PM
pws69's Avatar
pws69
Hurts like a mf, doesn't it!!!
AND it's quick!!!
Old Jul 25, 2008 | 02:38 PM
rcread's Avatar
rcread
AND it's quick!!!
Funny, I thought to push down on the wipers but was worried I'd lose a finger or two. I'll find something to slip in there tonight.
Old Jul 25, 2008 | 02:43 PM
pws69's Avatar
pws69
If you have a wood paint stir stick laying around, that would be good to use - thin enough and won't crack the windshield when the door slams on it!!
Old Jul 25, 2008 | 02:57 PM
Alan 71's Avatar
Alan 71
Just a reminder... the vacuum holds the wiper door and headlight doors closed. So you're looking for a leak in the actuator, or the relay, or the solenoid under the right wiper arm as has been suggested.The lack of vacuum makes the actuator think it's been signaled to open.
Regards,
Alan
Old Jul 25, 2008 | 04:17 PM
7T1vette's Avatar
7T1vette
Old Jul 25, 2008 | 04:48 PM
AK454's Avatar
AK454
Cruising
I am having a related issue with my wiper door. Mine will not pop up, you guys have any ideas where to take a look to fix the problem?
Old Jul 25, 2008 | 09:14 PM
C3 Stroker's Avatar
C3 Stroker
Will the override switch pop it up....
Old Jul 25, 2008 | 10:51 PM
Jack71's Avatar
Jack71
My wiper door closes on the wipers and crushes them unless I use the override switch. I figured out the problem a few months ago, but forgot the fix. So I'll have to re-diagnose. Ughhhhh.
(Sorry for the thread hijack)
Old Jul 28, 2008 | 09:10 PM
AK454's Avatar
AK454
Cruising
Stroker, I have tried the override switch with no luck. I can manually open if I remove the grate. It will stay up, and will return to the down poistion when I turn the wiper switch off. Is the control valve the problem?
Old Jul 28, 2008 | 10:13 PM
...Roger...'s Avatar
...Roger...
With the engine running remove the small hose from the wiper door relay...the door should pop up.Let us know if it does or doesnt.
To Wiper door
