Engine flush question
Old Jul 27, 2008 | 05:27 PM
Joe45's Avatar
Joe45
Default Engine flush question
My engine has 140,000 miles on it. Runs good. Just changed plugs. No evidence of oil burn etc. I would like to use one of those de-sludge adds before I drain my oil. Has anyone used these and could you suggest a brand as well as pro's and con's? Thanks
Old Jul 27, 2008 | 05:39 PM
A88FXRS's Avatar
A88FXRS
dont mess with good luck. use a premium detergent motor oil and enjoy.
Old Jul 27, 2008 | 05:43 PM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
I would stay away from the flushes. Change your oil more often if you are concerned about sludge.
Old Jul 27, 2008 | 06:24 PM
wombvette's Avatar
wombvette
Dont mess with it.
Old Jul 27, 2008 | 07:24 PM
7T1vette's Avatar
7T1vette
Unless you are planning to do a rebuild soon and just want to clean it out first, don't 'press your luck'. If you tried it and a lot of sludge broke loose, it could plug up the filter and cause it to go to bypass mode...dumping all the gunk through the bearings, bushings, rings, etc. If you really feel that you need to de-gunk the heads and pan, but don't want to do a rebuild, just pull the valve covers and use degreaser on the valve train and casting (letting junk flow into the pan via the drain holes) then flush same with cleaner and clear drain holes. Then drop the pan, clean it out and put on new pan and valve cover gaskets, fresh oil and filter. Run for 200-300 miles and change oil and filter again. That's a lot of trouble to get an "as is" engine cleaned up. Alternative is to use a good brand of detergent oil, do 3000 mile oil changes and wait for the next rebuild.
Old Jul 28, 2008 | 01:30 PM
jackson's Avatar
jackson
start by changing to Shell Rotella T 15W-40 & a WIX filter ... about $10/gallon & $6 each at local discounters ... do it every 3K-5K miles.
Old Jul 29, 2008 | 10:08 AM
vetteguy75's Avatar
vetteguy75
LA Events Coordinator
When I was in college I made the mistake on "flushing" my engine in a 1965 6 cyl Ford Falcon with 185,000 miles on her...of which I put 100,000 miles myself....want to "make the engine better" Prior to the flush, she ran perfectly...no oil burning, smooth idle, and good torque (as well as a 6 cyl can do)...anyway, after the flush....the engine ran terrible...could not get it to idle properly and THEN she started to leak from the rear seal and from the front! Then the final straw....the engine started to burn oil out the PCV tube (it was not the PCV we know today but just a tube that came out of the engine and ran down the side). Had to get rid of the car and go with something else dependable. SO...DON'T DO IT! The ole' saying...."If it ain't broke....don't fix it!" is appropriate here!
Good Luck!
Old Jul 29, 2008 | 01:36 PM
tabbruzz's Avatar
tabbruzz
Good Luck!
Things have changed for sure and you should not have any issues. A lot of dealerships use this brand which happens to be a relative of mine...
http://www.envirolution.com/
Old Jul 30, 2008 | 07:36 AM
FB007's Avatar
FB007
Originally Posted by wombvette
Dont mess with it.
Old Jul 30, 2008 | 01:05 PM
Mike Ward's Avatar
Mike Ward
Envirolution. I guess that's the latest way of spelling snake oil.
Old Apr 25, 2009 | 10:52 PM
raulotero91's Avatar
raulotero91
could it be an engine drain plug? water jacket core plug leak? but idk what those are? thats one of the possibilities listed in the repair manual
Old Apr 25, 2009 | 11:54 PM
PeteZO6's Avatar
PeteZO6
After I removed the original 132,000 mile engine in my '69 I took the tin off to see how the internals looked. It was so clean you could see the white paint dabs on the parts like the rods, valve springs, etc. How did it stay so clean? Regular oil and filter changes every 3,000 miles. Now they say that is too often, maybe so, but frequent oil and filter changes will keep the engine happy for many thousands of miles. Skip the snake oil, just use motor oil!
Old Apr 26, 2009 | 08:29 AM
baxsom's Avatar
baxsom
seafoam?
Old Apr 27, 2009 | 12:31 AM
RIJVETTES's Avatar
RIJVETTES
Originally Posted by baxsom
seafoam?
Now this stuff works! It ain't snake oil. Just follow the directions.
Old Apr 27, 2009 | 07:25 PM
Reggie Dunlop's Avatar
Reggie Dunlop
Seafoam does work.
Old Apr 27, 2009 | 07:51 PM
71coupe454's Avatar
71coupe454
If you have a lot of crud build up in your engine, under the valve covers is where most of it is going to be. Dig, scrape, pick all that out first and then run cleaner to get it all cleaned out. The cleaner wont dissolve all that stuff and it sure aint gonna go through the oil returns.
Old Apr 27, 2009 | 10:13 PM
PuddleJumper's Avatar
PuddleJumper
Seafome good. engine flush bad if you think about it its got to be more like a solvent witch will do bad things
To Engine flush question
