Easy OD Trans?
Old Jul 28, 2008 | 11:06 AM
HO-alts-Rick's Avatar
HO-alts-Rick
Default Easy OD Trans?
What is the easiest OD swap into an 81? Does anyone have a complete kit available? What all is needed?
Old Jul 28, 2008 | 11:55 AM
Durango_Boy's Avatar
Durango_Boy
Bowtieoverdrives.com will have a kit for your car. I suggest the TH2004R.
Old Jul 28, 2008 | 02:05 PM
7T1vette's Avatar
7T1vette
Hmmm. I thought the '81 came with an overdrive tranny from the factory.??
Old Jul 28, 2008 | 02:08 PM
Durango_Boy
..and here I thought it was '82. I don't recall anymore.
Old Jul 28, 2008 | 03:26 PM
kevinator80's Avatar
kevinator80
My gray matter is telling me the 82 was the first year of od (700r4) and the 81 came with a lock up convertor but still a turbo350 tranny.
Old Jul 28, 2008 | 03:33 PM
mrvette's Avatar
mrvette
NO it has a lockup 350 tranny, known as the 350C unit....
the same plug setup works for the 200 4r I understand, IF so you have a drop in swap.....
damn nearly....
Old Jul 28, 2008 | 03:59 PM
HO-alts-Rick
This is correct for my 81 anyway.............
Old Jul 29, 2008 | 01:51 AM
7T1vette's Avatar
7T1vette
I stand corrected. Lockup clutch w/o overdrive in 81.
Old Jul 29, 2008 | 09:16 AM
c69vete's Avatar
c69vete
Finalist 2021 C3 of the Year - Modified
2017 C3 of Year Finalist
Cruise-In VIII Veteran
St. Jude Donor '07
The 200r4 is indeed the easier swap. If you are running much more than stock power, you will have to beef up the tranny during the rebuild. If you buy one from one of the vendors it will already have the stronger hard parts in it. Your existing trans yolk and trans mount will work. You will need to get the shifter kit if you want to be able to pull it into low.
Old Jul 29, 2008 | 07:52 PM
redwingvette's Avatar
redwingvette
I got my 200-4R from BTO and it has worked great since April, 2003.
Trans install
To Easy OD Trans?
