Maximum horsepower without touching bottom end
Old Aug 7, 2008 | 11:08 PM
chevr0letman's Avatar
chevr0letman
Default Maximum horsepower without touching bottom end
Hello all,
Can anyone tell me what is the maximum amount of horsepower for a 350 without touching the bottom end of the engine?
The setup I want is supposedly going to produce around 420 horses according to desktop dyno.
Compression isn't going to be over 9.2 an I'm going to upgrage to 3.73 gears and a beefed up 700r-4 rated at 550hp.
Thanks in advance!
Old Aug 7, 2008 | 11:27 PM
73, Dark Blue 454's Avatar
73, Dark Blue 454
The rotating assy should be fine at 420 with an NA engine.
But 420 will be difficult with 9.2 compression ratio. You'll need to spin her about 6500+ RPM which means you'll need a cam in the 250 @ .50 range, which needs much more than 9.2
My opinion.
Old Aug 8, 2008 | 12:23 AM
fauxrs2's Avatar
fauxrs2
Which bottom end? L-48 or L-82.. either will actually stand 420hp, but the latter will hold up a good deal longer than the former
Old Aug 10, 2008 | 11:50 PM
chevr0letman
L-42. I'm adding Brodix Ik180's so it should bring my compression up to 9.2, but I don't really want to touch the bottom end so should I just run with thinner gasket to bump up compression?
And how long is my engine going to last with 2 bolt mains and 420 horses?
Old Aug 11, 2008 | 12:18 AM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
Depends on how much and how many times you want to use it!!
Seriously..the stock bottom end can handle 400-425 easily. The weak point will be cast pistons and make sure there is NO detonation. They won't last long that way.
JIM
Old Aug 11, 2008 | 01:49 AM
billla's Avatar
billla
St. Jude Donor '14
I generally consider the stock bottom end of a 2 bolt to be good for around 400 HP with stock bolts - 475 with ARP studs.
Completely agree that any detonation is going to end the party quickly.
I can't see 420 FWHP with the IDK180s - what cam/intake/headers are you using?
Old Aug 12, 2008 | 01:46 AM
chevr0letman
Default *****
268 duration cam. performer eps manifold. full long tube headers, straight pipes.
I don't expect 420 from that little combo but desktop dyno says anywhere from 390 to 420 for a couple different scenarios.
I expect 350 at the wheels bud.
Old Aug 12, 2008 | 10:07 AM
billla's Avatar
billla
St. Jude Donor '14
268 duration doesn't tell me much - do you have a specific manufacturer?
I have DD Advanced and Dynomotion - if you email me the specs I'll take a swing; I've generally been within 5% or so.
Old Aug 12, 2008 | 10:27 AM
Backstop's Avatar
Backstop
I am interested in how this setup work out, too. Next year I would like to get my 1973 L-48 making 300 at the wheels and would rather not pull the engine. So if it can be done that'd be interesting.
Old Aug 14, 2008 | 10:50 PM
chevr0letman
the cam is this one
http://store.summitracing.com/partde...4&autoview=sku
I'll keep ya'll posted on the progress but even if i don't have 400 horses, as long as my 0-60 is around 5 I'll be happy destroying ricers.
Old Aug 15, 2008 | 01:47 AM
billla's Avatar
billla
St. Jude Donor '14
I took a look at this combo tonight.
First comment is those heads flow to .500...so you need more lift.
http://www.brodix.com/heads/ik.html
As spec'd I saw 392HP@5500 with over 400TQ from 2500-5000 RPM...nice
Moving to the X274E cam took us to 402@6000 over 400TQ from 3000-5000 RPM. If you have the gears, it'd be worth looking at this cam or a retrofit roller if you have the cash.
IMHO, that's as far as that combo goes without more CR or even more cam...probably a retrofit roller. You'd need to make 440+ at the flywheel to get 350 at the rear wheels, using an 18% drivetrain loss (automatic).
Based on my experience, these are pretty realistic numbers - but all IMHO of course.
Old Aug 18, 2008 | 12:12 AM
chevr0letman
So basically, the only thing holding me back is a higher lift cam?
To Maximum horsepower without touching bottom end
