Available lift height using engine hoist
Old Aug 9, 2008 | 10:14 PM
r3rep's Avatar
r3rep
Default Available lift height using engine hoist
Can anyone thats used an engine hoist to remove the body let me know how much height is possible and the technique you used. Just finished building the dolly with 32" uprights and am doubting the cherrypicker will lift the body high enough to get the dolly under.
Old Aug 9, 2008 | 11:21 PM
dannyman's Avatar
dannyman
I didn't use an engine hoist to lift the body off, but can tell you that you'll probably need 32" + just to clear the fuel tank. I've seen threads here that show the hoist located inside or just on top of the interior compartment. Whichever way you can safely lift the body.
I would say the trick to the whole procedure is to lift the body and roll out the chassis, followed by rolling the body stand under the body as opposed to trying to move the body with the hoist.
Old Aug 9, 2008 | 11:30 PM
r3rep's Avatar
r3rep
I'm not worried about the frame at all, as it is totally stripped. My concern is getting the body high enough to roll the dolly under.
Old Aug 10, 2008 | 12:09 AM
...Roger...'s Avatar
...Roger...
The ceiling in this garage is 8'6"
Old Aug 10, 2008 | 01:40 PM
tt 383's Avatar
tt 383
Just checking on my summit hoist, it looks to me like you could raise the initial height of the boom somehow by adjusting the rams height up with a spacer, or the rod with a spacer between the end of it and the base of the boom. The boom looks as though it will pivot much higher than the ram will take it. Just a thought if your ram doesnt go very high.
Old Aug 10, 2008 | 06:30 PM
stpman's Avatar
stpman
I made a longer arm for my hoist to get the hook to 9 ft
Old Aug 11, 2008 | 07:23 AM
ikwhite's Avatar
ikwhite
Default Used a cherry picker for body seperation
You can check out this link to my body seperation using a cherry picker I had no trouble using a cherry picker to pull off the body and place it on my dolly. I did have to shorten my straps though.
http://www.vettemod.org/index5.html#
ikwhite
Old Aug 11, 2008 | 07:41 AM
...Roger...
The look on the lady's face in the background is priceless.Oh honey what did you do now?Oh honey I was taking the vette to work today.Oh honey do you know how that goes back on?
Old Aug 11, 2008 | 10:54 AM
jnb5101's Avatar
jnb5101
two major problems to watch for. first, most of your lift height is lost in the strapping from the hoist to the car. that's where a frame like DW's comes into play. it keeps the straps short and more vertical than horizontal. i made mine out of 2x6 in a ladder shape, using the side legs to strap to the car and the center rung to attach to the hoist. second, as the hoist arm lifts, it will get very close to the side leg of the lift frame and limit the lift height. some guys lift the body, remove the wheels and lower the car frame onto car dollys and roll it out of the way.
Old Aug 11, 2008 | 11:47 AM
stpman's Avatar
stpman
DWncchs
I get that look a lot
Steve
Old Aug 12, 2008 | 01:02 AM
r3rep's Avatar
r3rep
Got the body off with the lift straps and engine hoist tonight. It was a pretty hairy experience by myself. Thank God my body is in primer. I didn't have the straps set right and the nose was very low. Found out later tonight, the straps are two different lengths. The hoist cyinder was right against the driver's door and scratched up the primer. I wouldn't suggest this method to anyone working alone. Wasn't even close to the 3' I needed for the tall dolly I built. Plus didn't consider having to deal with the legs on the hoist when moving the dolly under. Just had one of those nights that nothing went right.Will have to nurse my wounds and try again tomorrow.
Old Aug 12, 2008 | 03:54 AM
hunt4cleanair's Avatar
hunt4cleanair
Old Aug 18, 2008 | 12:43 AM
Blain's Avatar
Blain
I borrowed a lift strap assembly from my local Vette restorer. Found that they are way too long unless you could lift from 20' high. Instead I bought 3" ratchet straps pulled them down to the "T" top brace. I was using a 11' high gantry and come-along but even an engine hoist with this arrangement should get you high enough.
Blain
To Available lift height using engine hoist
