Starter recomendations
Old Aug 21, 2008 | 07:35 PM
68/70Vette's Avatar
68/70Vette
Originally Posted by 69Vett
Sorry, surely you don't beleive everything you read on the Internet.It is phsyically impossible for it to be a Gear Reduction.
you have to have room for the gears, (Gear Reduction)
wish requires the motor to be offset from the drive shaft.
Weight: 8.5 lbs.
While I don't believe everything on the internet (or anywhere else), I would like to point out that I referenced PowerMaster's own advertisement and technical description.
Furthermore, it would be quite easy for the motor cylinder axis and the drive gear to be on a common axis and still be a gear reduction motor. If it used planetary gears, the axes of the motor and gear drive would be the same; i.e. in a straight line - just as the picture of the starter shows. There's nothing exotic about planetary gears - they are used in all automatic transmissions and were used in Ford Model T's.
This starter looks exactly like the GMPP ministarter for 502 engines and it too is described as a gear reduction starter.
Anyhow, I have the GMPP version of this starter, but I'm not going to take it apart - I prefer to believe that PowerMaster and GMPP are both accurately describing this starter as a gear reduction starter.
Old Aug 21, 2008 | 09:41 PM
b71vette's Avatar
b71vette
ok , I've done some more research, these permanent magnet gear-reduction starters use planetary gears which allow the armature shaft and drive gear to be on the same axis, they do not use "OFFSET GEARING". I looked up planetary gears on wikipedia to see how they were designed. please take a look and you can understand how the armature shaft and drive gear can be on the same axis. It just looks like a mini OEM starter, but the newer technology/planetary gears is what enabled the gear reduction.
http://en.wikipedia.org/wiki/Planetary_gear
Old Aug 22, 2008 | 08:13 AM
pws69's Avatar
pws69
Welcome to the world of Planetary Gearing......
Well done "b71vette"
**** take it apart, you will find 1 shaft, no gears.
These use the the words, but it should read~
"4.4:1 Gear Ratio"
Permanent Magnet Delco Starter
Clears All Headers
"4.4:1 Gear Reduction Ratio"
Cranking Power for up to 10.5:1 Compression
Mounting Bolts Included
Dyno Test Results Included
Weight: 8.5 lbs.
Old Aug 22, 2008 | 08:43 AM
69Vett's Avatar
69Vett
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
I see that now, thank you for pointing out the plantary gearing, I was not aware of starters being manufactured this way.
Old Aug 22, 2008 | 09:23 AM
61 vert's Avatar
61 vert
Default Shims
To avoid shimming and starter engagement aligning issues, ALWAYS reuse the original nosehousing when possible when dealing with the small block chebbie.
Old Aug 23, 2008 | 12:27 AM
b71vette's Avatar
b71vette
pws69 Thanks for the compliment. I have been curious ever since I had this starter and how it accomplished the gear reduction. This thread put me over the edge and caused me to dig and find the answer.
Thanks to 68/70Vette he mentioned this starter may use planetary gearing which gave me the lead on getting to the bottom of this.
Check out this link it gives some details on the design and also a diagram of the internal parts. this is a Ford Starter but the Chevy is the same design but with different mounting set-up. click on the full view of the schematic on the second pic and you can see the internal parts that make up the Permanent Magnet Gear Reduction Starter.
Google Search is priceless!!
http://www.fordmuscle.com/archives/2001/08/ministarter/
Old Sep 1, 2008 | 01:05 AM
jimbux's Avatar
jimbux
Whatever you do, if your starter is OEM, be sure to KEEP it. I have a 1969 and recently put back in my original starter -- many aftermarket models simply won't fit !!!
Old Sep 1, 2008 | 07:41 AM
jb78L-82's Avatar
jb78L-82
Originally Posted by FB007
The same one. Just get $4.00 worth of brushes from NAPA and rebuild it yourself. A monkey can do one in 2 hours.
I had my original starter rebuilt by a machine shop about 15 years ago and it has worked perfectly since then for $50. No heat soak issues either. I may do it myself the next time with the new brush kit from NAPA as well. I would keep the original starter! Save your money and keep it original, if possible.
