Starter recomendations
Old Aug 15, 2008 | 04:44 PM
ron69's Avatar
ron69
Default Starter recomendations
To make a long story short, my starter went out last night at Walgreens driveup. Just a little embarassing! What is a good replacement starter for a 69' coupe with 350ci/th400 auto trans?
Ron
Old Aug 15, 2008 | 05:51 PM
69Vett's Avatar
69Vett
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
if your not worried about orginal,
I would suggest 1 of the gear reduction starters,
they work better and no heat soak
I think the brand I got was Pro-Comp.
works great , be sure to properly setup the new starter, adjust starter engagement, and shim properly for the flywheel.
Old Aug 15, 2008 | 09:51 PM
weimer20's Avatar
weimer20
Old Aug 15, 2008 | 09:53 PM
Ironcross's Avatar
Ironcross
Ron
a quality rebuilt!
Old Aug 16, 2008 | 05:29 AM
hunt4cleanair's Avatar
hunt4cleanair
More importantly is whether your current starter is a correct date code and part numbered that match your power team configuration. Owners pay big bucks for those so you don't want to trade it in as a core for a cheap starter replacement.
Old Aug 16, 2008 | 08:49 AM
markdtn's Avatar
markdtn
Whatever you do, if it is original keep it for posterity. If you don't care about original looking, replace it with a gear reduction type. C4s use those, also say 95 Suburban. If you go that route, you will have to ignore the yellow wire to the coil or add a relay. If you want original loooking, I recommend a Delco rebuilt from Advance or O'Reileys-not the house brand.
Old Aug 16, 2008 | 11:09 AM
b71vette's Avatar
b71vette
if you aren't concerned about keeping all OEM, her is what I recommend. It's a powermaster with gear reduction and uses the more rigid diagonal bolt pattern, has the nose case bearing support. basically the same design as OEM but smaller. I've excellent results with mine, I have this design but mine is the "Mean Green" brand which is more heavy duty. Mean Green says they sell alot of these for RVs with the 454 engines, Delco also sells this design. no heat soak issues so far. about half the wait as the orig starter.
Old Aug 16, 2008 | 11:10 AM
b71vette's Avatar
b71vette
should have mentioned this is for a 168 tooth flywheel, will not work with 153 tooth
Old Aug 16, 2008 | 11:44 AM
IrishJoker's Avatar
IrishJoker
After trying two rebuilt from Delco Remy, I went to an AC Delco store and got the "REAL" AC Delco replacement starter for my 81. All other replacments I tried had the dreaded "Heat Soak" problem and would leave me stranded until they cooled down. So if you want original look up AC Delco on line and see if there is a store near you.
Old Aug 16, 2008 | 08:00 PM
ron69's Avatar
ron69
Thanks for all the responses! A friend of mine rebuilt the starter this morning. The brushes were worn all the way down and shorted it out. I wanted to stay original if possible, and so far this is working. I have saved everything I have replaced so far. If this does go south again I'll go to a gear reduction starter and save the original.
Thanks again.
Ron
Old Aug 16, 2008 | 09:06 PM
gofastvette's Avatar
gofastvette
Just a couple of things,
The pictured starter is not a gear reduction starter. It`s actually a OEM permanent magnet starter I believe first introduced by GM around 1988. and, 2
No such animals as 'heat soak' starters.
Old Aug 17, 2008 | 12:16 AM
b71vette's Avatar
b71vette
Does have gear 4.4:1 Gear Reduction Ratio, check the link to Powermaster website.
http://www.powermastermotorsports.co..._starters.html
Old Aug 18, 2008 | 09:17 PM
Ironcross's Avatar
Ironcross
It`s not a gear reduction starter. The information is not correct. Merely a stock late model GM metric starter fitting most V8`s both BB and SB engines. The armature goes straight through the starter without any side reduction gear. It`s really a permanent magnet starter. I dont know if any GM starter is a gear reduction. Most of the gear reduction starters are made from imported models as is Chrysler's of foreign origin.
Old Aug 18, 2008 | 11:40 PM
FB007's Avatar
FB007
Ron
The same one. Just get $4.00 worth of brushes from NAPA and rebuild it yourself. A monkey can do one in 2 hours.
Old Aug 19, 2008 | 10:48 AM
69Vett's Avatar
69Vett
you can tell the picture is not a gear reduction starter,
on a "gear reduction" the motor is offset of the drive pinion,
thus allowing for a gear in the middle, allowing gear reduction.
if the starter motor is in ine wih the starter nose,
it is a direct drive starter... Not a gear reduction.
I have used both,
I recommend the gear reduction for high compression motors.
Gear reduction starters, start easier and more reliable in my opinion.
69VETT
Old Aug 19, 2008 | 06:13 PM
68/70Vette's Avatar
68/70Vette
This looks like the mini-starter that GMPP recommends for 502 and up BB's. It's part no. 9000852. I bought one of these for my 70 BB. Yes it only works for the 168 tooth (14")flywheel.
They also sell a mini-starter for all 1958 - 1996 small blocks. It's part no. 12361146. It works with either the 153 tooth (12.75 inch) or the 168 (14") flywheel. I have one on my ZZ4. It's so much lighter than the stock starter. This mini-starter is relatively reasonably priced..I forget how much. The 9000852 starter is more expensive. I think I paid $325 for it.
Old Aug 19, 2008 | 06:21 PM
68/70Vette's Avatar
68/70Vette
The GMPP 9000852 ministarter is a gear reduction starter. I have one and just installed it a month or so ago. I've looked closely at the starter pictured above. As far as I can tell it looks exactly like my GMPP 9000852 gear reduction ministarter. (Except of course the Powermaster logo is missing.) To see it's a gear reduction starter, I think you have to look at the side of the starter that's not pictured.
To Starter recomendations
Old Aug 21, 2008 | 12:38 AM
Ironcross's Avatar
Ironcross
Well your wrong!
I sell starters and the pictured starter is a direct drive Delco starter buiilt for GM fitting BB and SB V8`s. It is positively not a gear reduction starter. It was introduced as a light weight starter replacing the heavier similar off-set pattern aluminum nose going back to around 1970 with 350 and 454 engines. ....
Old Aug 21, 2008 | 06:19 PM
68/70Vette's Avatar
68/70Vette
Originally Posted by Ironcross
Well your wrong!
I sell starters and the pictured starter is a direct drive Delco starter buiilt for GM fitting BB and SB V8`s. It is positively not a gear reduction starter. . ....
I don't think I"m wrong. Look at the PowerMaster web site.
The photo we're talking about is the same photo PowerMaster uses to advertise the PowerMAX starter, part number 9200. The specifications of the starter state that it is a 4.4:1 Gear Reduction starter. It's identified as a gear reduction starter even thoght the axis of the motor cylinder is the same as the drive gear.
This starter is rated at 160 foot-lbs. They've got a bunch of other models going up to 250 foot-lbs.
Old Aug 21, 2008 | 07:01 PM
69Vett's Avatar
69Vett
Sorry, surely you don't beleive everything you read on the Internet.
It is phsyically impossible for it to be a Gear Reduction.
you have to have room for the gears, (Gear Reduction)
wish requires the motor to be offset from the drive shaft.
**** take it apart, you will find 1 shaft, no gears.
These use the the words, but it should read~
"4.4:1 Gear Ratio"
Permanent Magnet Delco Starter
Clears All Headers
"4.4:1 Gear Reduction Ratio"
Cranking Power for up to 10.5:1 Compression
Mounting Bolts Included
Dyno Test Results Included
Weight: 8.5 lbs.
