Aligning Doors
Old Aug 16, 2008 | 09:29 PM
BigJim13 JR.'s Avatar
BigJim13 JR.
Default Aligning Doors
HI,
just rebuilt both my doors on the 74, just curious but is there a general procedure for aligning and shimming them or is it just trial and error?
THANKS
Old Aug 16, 2008 | 09:59 PM
Artsvette73's Avatar
Artsvette73
Try aligning them up by the witness marks left by the washers that will get you close. You should have recorded the number of shims at each hinge.
Old Aug 17, 2008 | 08:49 AM
Alan 71's Avatar
Alan 71
I would caution you to be very careful with the gap at the top front of the door where it meets the top, rear, edge of the front fender. It's easy to get the door too far forward, or too high, which allows the door to hit the fender when you open the door or the front edge of the door can hit the top of the upper hinge when you open the door all the way to the stop.
I think it's a matter trial and error until you get the gaps the way you want them. You have to learn what effect the shims have and what effect moving the hinge bolts has. It's sometimes the opposite of what you think at first.
Regards,
Alan
Old Aug 17, 2008 | 10:48 AM
glassman74's Avatar
glassman74
Regards,
Alan
I agree with alan. It took me and a friend 4 hrs on the
pass. side door to get it right. Then I still had to sand
in the gap on the front edge of door to get it even.
Good luck.
glassman74
To Aligning Doors
