What should vacuum be?
Old Aug 19, 2008 | 09:50 AM
Fay vette's Avatar
Fay vette
Default What should vacuum be?
What should the vacuum be (in. hg) off the triple tree at the back of the manifold on the middle one for the transmission vacuum line. Stock 77 L-48.
Old Aug 19, 2008 | 10:05 AM
mrvette's Avatar
mrvette
15-18 is good more the merrier....point is that its STEADY...
Old Aug 20, 2008 | 08:55 AM
Fay vette's Avatar
Fay vette
I got a steady 14.5/15 on a cold engine at idle. What should the vac do on acceleration? More or less.
Old Aug 20, 2008 | 09:02 AM
SH-60B's Avatar
SH-60B
Vacuum drops on acceleration.
Old Aug 20, 2008 | 11:59 AM
7T1vette's Avatar
7T1vette
To really test what vacuum your engine is capable of maintaining, you need to remove the vacuum lines to all systems (including power brakes, headlights, wipers, etc.). With engine warmed up and idling, hook vacuum gauge to fitting (with other fittiing plugged off) and THEN read vacuum. At that point, you can also adjust the distributor timing to fine-tune it, if you want. That reading is your "baseline" vacuum reading. Now if you hook everything back on and measure vacuum again, you will see if you have any leaks in the vacuum system. Normal max vacuum on a stock 'base' engine should be 18-21" Hg. If you reconnect everything and get no more than 1" Hg (or so) drop in vacuum, you have a pretty tight system. Lower than that would indicate a leak path somewhere. If the system works fine, ignore the difference; if it operates poorly, find and fix the leak(s).
Old Aug 20, 2008 | 01:42 PM
Fay vette's Avatar
Fay vette
That 15 was only on the center post of tree to the transmission vac line. Still can't get it to shift right. Rest of system is just fine.
Old Aug 20, 2008 | 04:08 PM
bmotojoe's Avatar
bmotojoe
Something for you to look at as it happened to me. When you install the air cleaner make sure that the rubber line connected to the metal line going to modulator is not pinched. My car didn’t shift correct after I replaced the intake gaskets years ago and I found that the rubber line had been pinched down by the air cleaner just enough to cutoff vacuum.
Old Aug 20, 2008 | 04:51 PM
7T1vette's Avatar
7T1vette
If the tranny is not shifting soon enough, you probably have a vacuum modulator gone (going) bad on the transmission.
Old Aug 20, 2008 | 05:20 PM
TERRY CLARK's Avatar
TERRY CLARK
Bigger Cams will have lower vacuum.
Old Aug 20, 2008 | 05:53 PM
Fay vette's Avatar
Fay vette
I have a new moduator installed and I have checked the steel line. I blew it out and even installed a new line (rubber) line. Had governor cleaned. Its stumping 2 mechanic and a transmission guy as we speek.
Old Aug 20, 2008 | 09:27 PM
7T1vette's Avatar
7T1vette
If it is shifting early, the governor regulator valve (in the shaft of the governor) might be stuck also. If that is the case, you will shift at the same RPM's regardless of how much throttle you give it (light or heavy).
Old Aug 20, 2008 | 10:14 PM
Fay vette's Avatar
Fay vette
Its not ****ing into 3rd on its own, its holding 2nd under throttle until you let off the gas, then it will shift and ride 3rd until you give it more gas or you come to a grade. Then will come back up to 2nd. (see some of my other posts recently).
To What should vacuum be?
