Headlights Open After Engine Shut Off
Old Aug 19, 2008 | 10:08 PM
DaveN54's Avatar
DaveN54
7th Gear
Default Headlights Open After Engine Shut Off
Re: 1972. Headlights opened very slowly when I bought the Corvette. Traced all the vacumm hoses (per troubleshooting guide) and located leaks at the headlight actuator relays. Replaced the actuator relays and the seals on the larger acuators. Headlight opened/shut properly for several weeks. Now the headlight assemblies open as soon as I shut off the engine, about 75% of the time. ??? Any ideas?
Old Aug 20, 2008 | 08:08 AM
Durango_Boy's Avatar
Durango_Boy
Remove the check valve that keeps the vacuum in the system when the engine is shut off. Manually test is with your mouth, making sure you can only suck one way. If it's bad, replace it, and that might be your problem.
Old Aug 20, 2008 | 10:31 AM
Duke94's Avatar
Duke94
Yep, check valve.
Old Aug 20, 2008 | 09:09 PM
DaveN54's Avatar
DaveN54
7th Gear
I appreciate your suggestions, and will give it a try.
Thank you.
Old Aug 20, 2008 | 09:34 PM
7T1vette's Avatar
7T1vette
It also needs to be installed in the right direction...you should be able to suck air from the 'inside' end (but not from the 'outer' end).
Old Aug 31, 2008 | 09:48 PM
DaveN54's Avatar
DaveN54
7th Gear
You were correct.
New check valve solved the problem.
My thanks to each of you !!
To Headlights Open After Engine Shut Off
