Carb set-up!
Old Aug 22, 2008 | 01:13 PM
Apocolips's Avatar
Apocolips
Default Carb set-up!
Just bought a rebuilt Q-jet. Everything looks good on the outside. However, the two needle screws (idle screws) on the front of the carb are screwed all of the way in. How many turns should I open them to get a good first start? I have heard 2 full turns open to start. Any suggestions or experiences?
Old Aug 22, 2008 | 01:37 PM
SH-60B's Avatar
SH-60B
I'm not sure on the q-jets, but 2 turns ought to let it idle, then adjust from there for highest vacuum or turn them in til RPM just start to fall off.
Old Aug 22, 2008 | 02:59 PM
RonR80's Avatar
RonR80
St. Jude Donor '09
I go 2 1/2 to start gets you in the ball park!
Old Aug 22, 2008 | 03:03 PM
RonR80's Avatar
RonR80
St. Jude Donor '09
I go 2 1/2 to start gets you in the ball park! Make sure all the screws are tight and no vaccum leaks. Ron
Old Aug 22, 2008 | 04:08 PM
Apocolips's Avatar
Apocolips
Ok, I'll start at 2 1/2. Then while the engine is warmed up and at idle I close the screws until I hear the engine begin to stumble and then from that point back them out, what, about 1/2 turn?
Old Aug 22, 2008 | 05:45 PM
7T1vette's Avatar
7T1vette
That sounds about right. But you want to make sure your timing/distributor set up is right and that you have no vacuum leaks before you work on the carb. Otherwise, you could just be masking other problems.
Old Aug 22, 2008 | 06:57 PM
SH-60B's Avatar
SH-60B
I don't think it will stumble unless you go way to far. Listen for the rpm drop. When you 1st hear it, stop there. The vacuum gage is easier IMO.
Old Aug 22, 2008 | 07:21 PM
thegazman's Avatar
thegazman
Default thegazman
I bought a Q-jet from Jet Performance. They recommended 3 turns as a starting point.
To Carb set-up!
