71 BB Burping Coolant!!!
Old Aug 23, 2008 | 07:25 PM
MRANT212's Avatar
MRANT212
Default 71 BB Burping Coolant!!!
Just wondering what you all are running with thermostats!! Have a 71 454 4 speed and never ran into cooling problems until the past couple of weeks. Car always ran ar 210 and now occasionally it bounces to @ 220 or so. After turning the car off coolant boils up and pops out of the car. I havent done anything and figure start with a thermostat. Had the car now for 3 years and never changed it. Any advise out there?? Car is original with 81k on it. Thanks!!
Anthony
Old Aug 23, 2008 | 09:34 PM
69Vett's Avatar
69Vett
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
you don't say if it gets hot with highyway, or stuck in Traffic ??
from your general description, I would try a new Radiator cap.
Old Aug 23, 2008 | 09:42 PM
CCrane65's Avatar
CCrane65
I would replace the radiator cap first. It should be good to 15 pounds of pressure but they wear out.
If it won't hold enough pressure it will cause overheating as well as overflowing.
I used to have the same problem with a 65 small block. New radiator cap fixed it.
cc
Old Aug 24, 2008 | 10:57 AM
MRANT212's Avatar
MRANT212
Im going to grab a new cap...forgot that one!! Still wondering are you guys running a 180 thermostat???
Old Aug 24, 2008 | 01:13 PM
CCrane65's Avatar
CCrane65
I am in my 454. I used to run 160 back when these cars weren't so old. I may again just to keep the heat down. There is no need to be concerned about proper warm up with a big block nor is there a concern about lack of heat for winter time so why not?
cc
Old Aug 24, 2008 | 04:50 PM
69Vett's Avatar
69Vett
I just installed a 160, with 1 bleed hole, drilled in it.
Old Aug 24, 2008 | 06:22 PM
SmokinBBC's Avatar
SmokinBBC
Why a 160?
Old Aug 24, 2008 | 06:27 PM
SmokinBBC's Avatar
SmokinBBC
180 on my '70BB.
Old Aug 24, 2008 | 08:54 PM
69Vett's Avatar
69Vett
Any body's BB running to cool ?
Anybody's BB running to Hot ?
that's why.. 69VETT
Old Aug 24, 2008 | 09:57 PM
SmokinBBC's Avatar
SmokinBBC
that's why.. 69VETT
If it's running to cool, then a 180 might be better. No?
If it's running to hot, then something else might be wrong..bad tstat, restriction, fan clutch, shroud sealing...No?
Shouldn't a street engine be running around 185 to 195 degrees? Plenty of cooling threads on the forum. Hardly anyone using/recommending a 160.
Just wondering why you chose a 160 that's all. No biggie.
Old Aug 24, 2008 | 10:27 PM
CCrane65's Avatar
CCrane65
SmokinBBC, I for one have never heard of a big block running too cool. They generate so much heat it's almost impossible.
cc
Old Aug 25, 2008 | 06:33 PM
SmokinBBC's Avatar
SmokinBBC
cc
I know what you mean!
Old Aug 25, 2008 | 06:48 PM
400hp427vette's Avatar
400hp427vette
St. Jude Donor '09
Cap mostly is not holding to the lbs rating and thats why its burping
Old Aug 26, 2008 | 11:43 AM
69Vett's Avatar
69Vett
Remember a Thermostat's Job.
is to set the Minumium operating tempature of the motor.
If.... the rest of the system is working properly it will maintain that temp.
The higher temp. thermostat became standard, because of the
Emmision requirements..... Not for Optimum performance conditions.
69VETT
also, I live in Texas, we don't need heaters in the winter time!
IF I lived up North I might consider a warmer thermostat.
Old Aug 26, 2008 | 12:31 PM
bashcraft's Avatar
bashcraft
cc
Now you have. My 502 takes forever to warm up to 180. At least 5 0r 6 miles. And once it gets there it never gets any hotter.
Old Aug 26, 2008 | 10:14 PM
Sayfoo's Avatar
Sayfoo
180-190 is the ideal running temp for gas engines. This is well documented. A little higher is not really a problem, you just lose a little power while sucking in hot air. That's why people add cold air intakes.
But, the wear rate is dramatically higher when cooler. That is the reason that the majority of engine wear is at cold start up.
You DO want to get your engine up to temp as soon as possible. That is the purpose of the stat.
Old Aug 27, 2008 | 12:07 AM
70ZZ3 96LT4's Avatar
70ZZ3 96LT4
Default radiator level
my 70 with A/C has the big radiator and it shows how high the level should be cold. The level is not at the top of the cap, if it was filled to the top the fluid could be on the ground. Always have used the 180 thermostat. You may be keeping to much fluid in the radiator. I installed a coolant recovery tank on my 70. Real easy to do, just remove the vent grille and set it on the splash pan for installation, no more burping on the ground. This month makes 38 years driving this first new car I had ever bought, heck the 96 LT4 is the second and last.
To 71 BB Burping Coolant!!!
