77 corvette Q?
Old Aug 29, 2008 | 06:23 AM
jove987's Avatar
jove987
Default 77 corvette Q?
couple questoins regarding the 77 corvette i was think about change the air cleaner but i have herd there is a sencor in it how do i acomplish this then and then i was also think about changeing out my valv cover and dressing it ups a bit do i then need to put breathers i see vacum line going in to them please help
Old Aug 29, 2008 | 10:56 AM
Durango_Boy's Avatar
Durango_Boy
No sensors in your stock breather. First, if I may ask, why are you changing. The open element filters are cool and clean things up a lot but you'll get much cooler air through the stock setup.
If you want to remove the stock setup and replace it with an open element, and get new valve covers, all you have to do is put your PCV on the driver's side connected to the carb where it always was, and put a breather on the passenger side.
