My 74 has a stk PS pump. It leaks and makes noise as well as being the weak link in my Hydraboost. Is there a better pump to upgrade to, the stk is hard to fill. What are my options? TIA
You can get a rebuild kit for abiout $20. Its an easy job, so real special tools required. If you have to low pressure on the system I think you can change the reliefe valve spring seat pressure to cure it.
Maybe Jim Shea will pop in.
I've have the same question. I saw a car Saturday with a late model power steering pump with a remote reservoir. It looked way cool. Can we do that with our C3 Corvettes?
Bee Jay
Just make sure that you remove the spring, valve, and plunger from the back of the pump to transfer to the new pump. If the spring is bad, confer with Jim Shae about getting a proper new one. You want to keep the pressure regulated the same as it was stock.
