Painting sand-blasted frame
Old Sep 9, 2008 | 12:22 PM
jonny4523's Avatar
jonny4523
St. Jude Donor '05-'08
Default Painting sand-blasted frame
What kind of coatings has everyone used and your opinions of it?
I've seen the Por 15 system this this guy used:
http://www.corvette-restoration.com/...engthening.htm
I've heard of powder coating and dipping (where they dip the entire frame into a solution).
What has every used and how has it held up so far? I'm particularly interested in those who are done with projects and have road-tested it a little. Anybody have coatings that are already starting to corrode? Any driving a resto for a few years and still have the frame looking brand new?
Old Sep 9, 2008 | 02:12 PM
stinger12's Avatar
stinger12
I haven't driven my car yet, but I have experience trying to remove powdercoat from parts. I powdercoat a lot of my own stuff, and sometimes I have to redo a part because it turns out bad. I use aircraft stripper to remove the coating, and even that has a hard time removing the powdercoat. If it is properly applied and cured, that stuff ain't coming off. I have a friend who restored a thunderbird about 20 years ago. He drives it weekly and he had a few parts powdercoated 20 years ago - they still look perfect.
Old Sep 9, 2008 | 02:49 PM
jonny4523's Avatar
jonny4523
What all is involved in doing your own powdercoating? How much $ to get all the supplies needed?
Old Sep 9, 2008 | 03:09 PM
stinger12's Avatar
stinger12
Sandblast parts, blow dust off, wipe down with lacquer thinner, preheat parts in oven, wipe down parts again with lacquer thinner after cooled off, apply powdercoat, place in over to cure. I use the caswell powdercoating gun. check out their website for materials.
Old Sep 9, 2008 | 04:30 PM
Alan 71's Avatar
Alan 71
I had the frame on my 71 powder coated. It's holding up VERY well. You can't do the frame yourself unless you have a REALLY big oven in your garage.
Regards,
Alan
Old Sep 9, 2008 | 05:17 PM
7T1vette's Avatar
7T1vette
Pwdercoating is "purty", but you can't do it yourself and it is relatively expensive. The POR stuff is very messy, but you can do it yourself and it just takes time and patience. From what I understand, the POR [if put on correctly..per instructions] will hold up much better than the powdercoating; it is a stronger surface with more abrasion resistance. I think both are very resistant to normal water, weather, etc.; however, on the issue of road salt and other environmental "nasties", I would think POR would be the better choice. I moved from Indiana [after more than 50 years as a resident] and I know what kind of humidity, temp differentials, snow, ice, road salt, etc. you will have to deal with. Personally, I'd go the POR route. (But powdercoat is much easier to have someone else do and is still a good choice.)
Old Sep 9, 2008 | 05:33 PM
fe1ixdakatt's Avatar
fe1ixdakatt
What's a good price to have the frame of a 68 sandblasted and powder coated?
Old Sep 9, 2008 | 06:52 PM
stinger12's Avatar
stinger12
Usually you can get it done for around $700 Canadian.
Old Sep 9, 2008 | 07:55 PM
69Vett's Avatar
69Vett
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
Best bang for the buck.... POR15, it fills and self levels, great stuff.
69VETT
Old Sep 9, 2008 | 10:59 PM
72LS1Vette's Avatar
72LS1Vette
Take a look at the RustBullet website also. http://www.rustbullet.com
Very easy to use, goes on over bare or rusted metal with no prep other than cleaning.
I sandblasted the frame on my 72
gave it 2 coats of RustBullet
and topcoated with Rustoleum Satin Black.
I think the cost is about a wash compared to POR-15 but there is much less prep work involved.
Rick B.
Old Sep 10, 2008 | 12:29 AM
77TexVette's Avatar
77TexVette
Personally I have used the POR-15 products both inside and outside the frame. I am happy with them. I used an Eastwood undercoating gun to cover the inside of the frame - very messy, but effective.
Also, I hope you take the opportunity to strengthen the frame a bit now that it is all clean. There should be some basic reinforcements present that not only improve the strength and ultimate ride quality, but also the ssafety of the car, e.g. add gussets and weld the lower control arm mounts properly.
Here are some examples and pics of mods I made to the frame. There is other good info on the forum regarding this.
http://forums.corvetteforum.com/show...ighlight=frame
Good luck !
Old Sep 10, 2008 | 10:32 AM
jonny4523's Avatar
jonny4523
Good luck !
How many here do this? I wasn't planning on making any frame modifications. I'm not skilled enough with a welder to trust myself on something like this. So it would have to be done for me. I wasn't really planning on that cost.
Old Sep 10, 2008 | 10:35 AM
jonny4523's Avatar
jonny4523
Here is a local place for powdercoating:
http://www.indypowdercoating.com/index.php?P=auto
That price seems kinda steep. What can I expect to pay for POR15 supplies? I saw their prices on the internet, but I wasn't sure how much I'll need.
I have no problem with the time and mess.
Old Sep 10, 2008 | 01:59 PM
77TexVette's Avatar
77TexVette
I used about 1.5 qt of POR-15 and a qt of chassis coat. I sprayed it and maybe you'll use a little bit more by brushing it on.
Regarding the welding, I would at least check if there is any serious weakness or problem. I guess I just never have seen a sandblasted C3 frame that doesn't need at least a little work
Old Sep 10, 2008 | 03:01 PM
jonny4523's Avatar
jonny4523
Crap. That worries me. I have 100% faith in myself that I could quickly learn to weld. I have plenty of people around me on a daily basis that are master welders. So having someone teach me wouldn't be hard. But then I'd need to get a welder. Granted, I'd love to learn how to weld. If you can work with metal, you can build just about anything you could possibly imagine. But that wasn't really in the budget either.
Old Sep 10, 2008 | 05:40 PM
77TexVette's Avatar
77TexVette
Jonathan,
I'll send you a couple of pictures via PM so you can at least check if some vital areas are in need of attention. If so, maybe someone can lay down a couple of welds for you.
Some mods I made are truly only for racing while others are safety/stability items. A good reading is the Chevy powerbook article, which you can find on the corvettefaq web site. If you browse through the articles a bit you'll get a better feel of what to look out for.
http://www.corvettefaq.com/c3/ChevyPower.pdf
Old Sep 10, 2008 | 06:48 PM
Corellian Corvette's Avatar
Corellian Corvette
Remember, POR 15 works best on RUST. If you're putting it on a frame that's been blasted and rust-free, POR15 is not your best bet. POR15 is not a paint per-se, it's a chemical designed to bond with rust.
For a rust-free frame, Powdercoating is, without a doubt, the best option.
After that, your best bet at that point would be to prime, and paint with something like Easwood Frame coating which is very hard and durable. Again, I personally would not put POR-15 on a frame that's been blasted; it won't bond well and it won't last.
POR-15 is AWESOME if you have light surface rust and can't get the whole frame off for blasting. It will bond like a ***** to a slightly rusted surface.
To Painting sand-blasted frame
Old Sep 10, 2008 | 07:30 PM
Joe45's Avatar
Joe45
Hey, I have been powder coating for the last 15 plus years. It is a nice finish when applied. What end users should know is that the coating does not sacrifice itself to protect the base metal like Zinc coatings would. For example, if your frame was powder coated, got a nice stone chip in it(to bare metal) and was driven in rain, salt roads etc. the elements would attack the exposed area. Corrosion would "creep" from the exposed point under the powder coat. The appearance at the exposed & surrounding area's would look like a painted body area that has bubbles etc. underneath the paint. Basically coated blisters. Corrosion would continue unless corrected. With this said, I chose to use 2 coats of Zinc enriched epoxy primer followed by 2 coats of epoxy based satin black top coats for my frame. The Zinc enriched primer will "sacrifice" itself to protect the base metal.
Just my 2 cents on how I looked at treating my frame. BTW.. my frame was sandblasted and wiped down with wax/oil/grease remover after blasting. Prior to spraying the Zinc primer.
Old Sep 10, 2008 | 08:57 PM
jonny4523's Avatar
jonny4523
Which products did you use specifically? Something you ordered over the internet or something I could buy locally?
Old Sep 10, 2008 | 09:34 PM
rponfick's Avatar
rponfick
I have used PPG DP epoxy primer on the last three frames I have done, and am very satisfied.
Just another suggestion.
Ralph.
