Air Injection Reactor
Old Sep 14, 2008 | 11:23 AM
imariver's Avatar
imariver
Default Air Injection Reactor
Opinions Needed........
What are the pros and cons, cause and affects, whys and why nots of removing the A.I.R. from my 73 350 automatic?
Thanks, Steve
Old Sep 14, 2008 | 12:14 PM
stingr69's Avatar
stingr69
A.I.R. is a good thing when it works right. it draws little HP and makes the air we breathe better. You can take the belt off and do a road test to see what the HP difference is - not that you will notice if at all. The other plus is somewhat more room to work on the engine but that might not matter much to some people.
The only potential downside to having one in place is when it does not work right. You can get afterfiring in the exhaust when you let go of the throttle if the valve fails. More noticeable on a manual tranny car but it can have an effect on AT cars as well. If you do not have that problem, you might consider keeping it. New diverters are hard to find and I am not fully convinced that anyone is actualy rebuilding them. I see many high dollar so called "restored" systems with non-original looking diverter valves so I am still skeptical about anyone actualy rebuilding them, but I may be wrong there.
Hope this helps,
-Mark.
Old Sep 14, 2008 | 12:56 PM
7T1vette's Avatar
7T1vette
There are only two reasons to keep it: 1) if you need it to pass your state emissions inspection requirements..for having the correct emissions equipment on the car and meeting emissions limit requirements; or 2) because you want to keep the car in 'original' equipment. Reasons for removing it: it's ugly, it robs horsepower, if the engine is tuned properly there is little emissions benefit, and it adds weight that you don't need. Make your best judgement.
Old Sep 14, 2008 | 01:05 PM
a1sensei's Avatar
a1sensei
From what I understand, AIR does not actually cut emissions whatsoever, it was a way for automakers to comply with the letter (vs the spirit) of federal mandates. If it actually helped, they would still be using it, like cats. God bless, Sensei
Old Sep 14, 2008 | 01:06 PM
Mike Ward's Avatar
Mike Ward
For reference, the AIR pump draws a mighty 1 or 2 HP- at the most.
Old Sep 14, 2008 | 01:21 PM
FB007's Avatar
FB007
The solution to pollution is dillution.
Old Sep 14, 2008 | 01:23 PM
FB007's Avatar
FB007
Old style cats needed the extra air to work well. The newer style cats do not. Therefore, your right AND wrong.
Old Sep 14, 2008 | 02:26 PM
imariver's Avatar
imariver
Interesting answers / opinions...........
I may just remove the belt and see. The car is pretty much stock original and I plan to keep it that way, however I'm not totally against cleaning up the house either. If it does get removed though, will I get blamed if I forget to put it back on? lol
Old Sep 14, 2008 | 03:03 PM
7T1vette's Avatar
7T1vette
The A.I.R. pump merely blows excess air into the exhaust passage in the hope that it will help burn off any excess hydrocarbons. Obviously, if the car is not "running rich", it does not good at all. But, it was a "Band-aid" idea that addressed one potential issue with lowering emissions levels. Catalytic converters were a better attempt [albeit expensive] toward the "burn-off" effort. So, this pump does nothing for the proper operation/performance of your engine...it just helps to lower emissions IF your air/fuel mixture is too 'rich'. Dump it, if you don't need it; or, if you like originality, leave it there. {P.S. I would not just throw the unit away; there are lots of floks who will pay dearly for a complete and correctly dated air pump and hardware.}
Old Sep 14, 2008 | 03:31 PM
rayluka's Avatar
rayluka
I dont understand why my car would have a cat yet no A.I.R injector. It was originally made for Colorado and it passes smog here in CA. Its considered 49 federal . Go figure?
Old Sep 14, 2008 | 05:28 PM
SIXFOOTER's Avatar
SIXFOOTER
The Air pump is an ajunct to the cat, it pumps fresh air into the exhaust stream right at the head to keep the exhaust temp as high as possible going into the cat to make the CAT work better (burn hotter).
As stated above the newer cats don't need the extra air, so you could (theoretically) eliminate the pump, run a new cat and still pass emissions testing.
Old Sep 14, 2008 | 06:22 PM
jb78L-82's Avatar
jb78L-82
One more reason to dump the AIR pump besides all the reasons above, when I replaced my exhaust manifolds on my 78 L-82 with McJack's shorty headers, I was shocked at how big and how far the air tubes extended into the head. I have to believe that these ports create some turbulence and disturb the exhaust flow. They are pretty big tubes! I as mentioned above have everything that I took off the car. If I ever have a problem with emissions, I will just add two modern cats to the true duals to pass the emissions test (and have uncut head pipes for later). I wish the aftermarket industry would lobby for any car 20 years old and older be except from the emissions testing since so few cars that old are on the road and fewer still drive any significant miles. These older cars with or without emissions have virtually no impact on the air we breathe. Too few, no miles driven. It's all very silly.
Old Sep 14, 2008 | 07:26 PM
baxsom's Avatar
baxsom
[QUOTE=jb78L-82;1567104389] I wish the aftermarket industry would lobby for any car 20 years old and older be except from the emissions testing QUOTE]
no testing in my area for any car
Old Sep 14, 2008 | 08:05 PM
7T1vette's Avatar
7T1vette
Emissions testing requirements are on a state-by-state basis, with final approval being made by the Feds. Several states have recinded emissions requirements on "collector/classic" cars. Hagerty (insurance company) has been very instrumental in helping groups lobby and obtain such legislation. Maybe you need to start that 'movement' in your state...
Old Sep 14, 2008 | 09:43 PM
jb78L-82's Avatar
jb78L-82
Yes, I am aware of the state and Federal regulations. Federal regulations are fixed and apply nationally to everyone ( no final approval), state's testing is individually decided, as a monitoring mechanism of the Federal law. States that do not test older vehicles have chosen not monitor the emissions, but the state has not recinded the emissions requirement, since it is a Federal law which supercedes the state. Most New England States do not test cars 25 years and older, but it's the principle that bothers me. The other issue is that even in states with no testing, it is against Federal law to alter any emission's equipment, so in theory, anyone can get pinched, if someone wants to bust b**lls! In essense, even in states with no testing/inspections, you can be fined (federal not state law), of course, if caught. Thanx for the tip on Hagerty, who I use.
Old Sep 14, 2008 | 10:48 PM
imariver's Avatar
imariver
Sixfooter, that was a very interesting tid-bit of information about the high exhaust temperatures. Maybe that explains the excessive (and what I thought was unsual) amount of heat that was raditating from the manifolds at idle.
So, to recap, I guess that the A.I.R. looked good on paper and probably a good idea at the time. Thanks for all the help.
Old Sep 14, 2008 | 11:43 PM
a1sensei's Avatar
a1sensei
I don't know, but this is the explanation I heard: The gov required emissions to be reduced to X parts per million (PPM) at thye tail pipe by Y date. Blowing clean air into the exhaust, while not reducing the volume of pollutants, does reduce the PPM. Problem solved.
To Air Injection Reactor
Old Sep 15, 2008 | 09:09 AM
Bullshark's Avatar
Bullshark
CI 5 & 8 Veteran
Originally Posted by SIXFOOTER
The Air pump is an adjunct to the cat, it pumps fresh air into the exhaust stream right at the head to keep the exhaust temp as high as possible going into the cat to make the CAT work better (burn hotter).
Danny, As I am sure you already know, They put A.I.R pumps on some of the older cars, before CATS ever existed. My 70 LT-1 and the 69 427 390 hp had one, with no CAT. Then it was just to burn excess hydrocarbons.
Old Sep 15, 2008 | 02:52 PM
SIXFOOTER's Avatar
SIXFOOTER
Didn't think about that, but your absolutely correct.
Old Sep 16, 2008 | 08:12 AM
imariver's Avatar
imariver
If I disconnect either hose ( from the pump) that runs to the manifolds and put my thumb over the end of that hose, I can definately feel puffs (exhaust) of air comming out of the hose with the engine idling. does this mean that the check valve is failing? or is this just characteristic of the check valve.
Sorry, this is my first Corvette and I feel like I should be sitting in a cornner with a pointed hat on. ( and I have not received my service manual yet )
