a/c vents
Old Sep 17, 2008 | 03:01 AM
mejetdrvr's Avatar
mejetdrvr
Default a/c vents
here's the problem. my center a/c vent or deflector is falling out of the gauge bezel, or center dash, where the gauges are. its the 2 vents at the top. I'm missing the clips or retainers that holds the vents in place. I looked in the big companies catalogs(year one, eklers, mid america, vette central). but i can't find them. anybody out there has any info. please fill me in. its for an '80 vette. hope i'm descibling this correctly.
Old Sep 17, 2008 | 07:11 AM
7T1vette's Avatar
7T1vette
I don't believe that there are any 'clips' to hold them in place. I believe they just pivot in the housing they are in. But there are felt seals inside the housing which takes up the 'slack' you are seeing and prevent air leakage around them. Chances are those seals are shot. Just remove the upper vent housing (3 screws, I think), and you can get at them for repair. Buy a scrap of black felt and cut some strips to the necessary width; then use double-sided tape or non-hardening glue to put them into place. Stick the vents back in and you should be 'good to go'.
Old Sep 17, 2008 | 09:38 AM
gbvette62's Avatar
gbvette62
mejetdrvr, your right, the 77-82 plastic, center gauge bezel used spring steel clips to hold the center vents into the bezel. GM discountinued these years ago and no one has repoped them, that I'm aware of. I took a quick look around the shop, I use to have some from cars we parted, but didn't turn up any. Your going to have to find some used ones.
Old Sep 17, 2008 | 12:28 PM
7T1vette's Avatar
7T1vette
My bad.... I didn't realize there was a difference in design in late 70's C3's. Good luck in finding or fabricating the clips.
Old Sep 17, 2008 | 01:07 PM
mejetdrvr's Avatar
mejetdrvr
thanks for the info, hopefully someone will have some or know someone who does.
To a/c vents
