engine swap
Old Sep 18, 2008 | 09:46 PM
454vette's Avatar
454vette
Cruising
Default engine swap
What do I have to do to swap out a 350 for a 454 in a 73 vette, 4-speed?
Thanks,
Steve K.
Old Sep 19, 2008 | 04:56 AM
BenUK's Avatar
BenUK
I've no experience of this, but I've seen this asked before.
At least: Radiator upgrade, front suspension upgrade.
There may be more. Will a 454 fit under your hood? Will the power of the big block mean you have to upgrade your half shafts and other stuff?
Old Sep 19, 2008 | 08:29 AM
bashcraft's Avatar
bashcraft
Radiator should be fine. Front springs, depends, wait until after swap and see what it looks like. Halfshafts should be fine if the u-joints are good.
Basically you'll need accessory brackets and pulleys. I bought mine from Summit. Headers and exhaust. Maybe a hood. It's a pretty straight forward swap.
Old Sep 19, 2008 | 04:18 PM
Alan 71's Avatar
Alan 71
Hi Steve,
I'm thinking Ben is right about the radiator. I believe the BB radiator has a larger core than a SB radiator. The AIM does indicate that.
BB- UPC LS5, Sheet B4
SB- UPC 11, Sheet A10
You can bet that if it didn't need more radiator, GM would have saved the $$.
Regards,
Alan
Old Sep 22, 2008 | 07:18 AM
bashcraft's Avatar
bashcraft
My SB radiator does a fine job cooling my 502. Never has it gone above 180*.
Old Sep 22, 2008 | 10:00 AM
hugie82's Avatar
hugie82
I did a 427 in a 74 vette with no problems. Dr. Rebuild has all the P/S, ALT. brackets and engine mounts. My 350 rad. was OK but I got a good deal on a 4 core and dual Flex-o-lite puller fans slip rite in perfectly(Alt. amps. must be over 80amps).carb, trans, distributor linkage fit right in, 454 flywheel will be needed
Old Sep 23, 2008 | 09:04 PM
454vette's Avatar
454vette
Cruising
I just want to double check, does a SBC and a BBC use the same flywheel? I'm not talking flexplate.
Old Sep 23, 2008 | 09:30 PM
69Vett's Avatar
69Vett
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
"What do I have to do to swap out a 350 for a 454 in a 73 vette, 4-speed?"
Have your head examined ! I know I just did this....
You have to buy all the brackets and pulleys for a BB,
unless you want to beat your head on the wall.
Flywheel needs to for 454. ohh yea a BB radiator core support !
plus all the other stuff, waterpump, radiator, shroud, hoses, belts,
power steering pulley, fuel pump.
Front coil springs are different, unless you want the slammed look.
good Luck, 69VETT
Old Sep 23, 2008 | 09:58 PM
hugie82's Avatar
hugie82
good Luck, 69VETT
Hold on,I used my 74 350 shroud! just remove the 3 inch extension that is stapled on. Radiator works if you have no A/C. Hoses were trimmed. P/S and ALT brackets, spacers and bolts were about $300 from Dr Rebuild. P/S pump and pulley worked perfectly. No spring needed it only lowered the car an inch but if it really bothered you, you can get coil over shocks or spurge $100 for new springs OH YEA... to answer the post above, 454 BB is externally balanced so your SB 350 will not work. If you used a 396/427 BB than the 350 would work
Old Sep 23, 2008 | 11:19 PM
69Vett's Avatar
69Vett
just because something works, doesn't make it right.
When someone asks for recomendations I would much rather recommend the right parts,
than suggesting what might work,
for Instance BB power steering uses a double pulley configuration,
sure you can jury Rig other combo's.
Like wise someone going to the trouble and expense of moving to a BB,
I would never recommend keeping the orginal used SB radiator, now if the owner elects to take short cuts thats their business.
I prefer the right way, instead of the maybe way, to each his own. 69VETT
Old Sep 24, 2008 | 10:05 AM
hugie82's Avatar
hugie82
AHHH it's nice to have $$$$. At the time I didn't but you would not be able to tell I swapped and used the original 350 parts unless you started checking numbers! I don't recall what year brackets I used but it was 73 or 74 BB but I only recall a double pull on the A/C cars, MINE WAS NOT. The shrouds are the same shroud once you remove the stapled on extention. The radiator I made it clear, "IT WAS OK FOR A NONE A/C CAR" and you would have to crawl in pretty deep to tell me it's the wrong rad. The hoses have the same angles from SB to BB after you cut 2 inches off they fit perfectly but I'm sure most people can splurge on two new BB hoses for $30 bucks. My hoses were new, so I saved a buck with no risk IMO. All these mods are what GM does on all their car. Obviously if a belt was slipping, engine over heating, hose kinking, ect... to go back and replace one of these parts is not a big deal but the way some of you guys act you woud think I was using duct tape and rope.IMHO
Old Sep 24, 2008 | 12:39 PM
bashcraft's Avatar
bashcraft
By "right" do you mean as trying to pass the car off as an original big block?
As well as all the small block parts work with my 502, why would you want to waste all that money and gain nothing?
Old Sep 24, 2008 | 09:27 PM
69Vett's Avatar
69Vett
This tread is not about your car, or my car,
it is about what would you recommend to someone for installing a BB motor.
With all the over heating threads on this fourm,
I cannot believe anyone would recommend leaving a SB used radiator,
in place with a clear conscience.
I will post no more on this thread.
Old Sep 24, 2008 | 09:33 PM
markdtn's Avatar
markdtn
Not necessarily. A 400 SB and a 454 (and 502?) BB are both externally balanced. A 350 or 327 (283, 307....) SB and 396 and 427 BB are internally balanced and will all interchange.
Old Sep 25, 2008 | 07:39 AM
bashcraft's Avatar
bashcraft
I can guarantee you that most of the overheating problems here are not because of the radiators. They're caused by missing spoilers and seals, bad fan clutches, electric fans which are too small or not operating properly, incorrect timing and many other things which throughout the years people have modified or simply removed.
I have issues with people who, when giving advice, the first words out of their mouth is "spend lots of money and replace it". Contrary to popular belief, there is nothing wrong with the cooling systems on these cars if everything is in proper working condition. I think I've proven this by cooling my 502 with a small block radiator.
Old Sep 25, 2008 | 10:47 AM
hugie82's Avatar
hugie82
I never had a cooling issue w/ the 4 C3s I've owned over the years. I will say an A/C vette in traffic on a hot day w/ the a/c blasting may be pushed to its limits if one or more parts are not 100% IMO
To engine swap
