shifter linkage??
Old Sep 20, 2008 | 01:05 AM
wro87's Avatar
wro87
Default shifter linkage??
My 19yr old son is a little sad trying to get the coupe ready for Funfest and have a little set back. WE have gotten all the interior back in on our 71 coupe, Now the shifter linkage will not lets us go into reverse, 1st/2nd. The only way we could get it to work was to remove the trim plate from the center console and the stick still hits the side of the center console when we go into reverse still. When we bought this car the interior was out but it would shift ok. It is a 350 4spd with ac nothing fancy. Could the linkage be out of adjustment?
Any assistance would be greatly appreciated
Thanks gang wro87
Old Sep 20, 2008 | 09:20 AM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Bolt the shifter lever on the other side
Old Sep 20, 2008 | 09:23 AM
69Vett's Avatar
69Vett
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
Yes the linkage may be out of adjustment, either it is not aligned or the trigger pull pin is not releasing properly. you might also remove the reverse arm from underneath, to verify the Tranny is not jamming up. There is an aligment procedure,
my best guess is the reverse pin is not releasing if everything else seems ok.
one other thing, if you still have the Reverse interlock cable connected, if it is frozen/rusred, this also may prevent shifting into reverse.
good luck...69VETT
Old Sep 20, 2008 | 12:13 PM
65GGvert's Avatar
65GGvert
Re read the original post. There's no way the linkage adjustment can cause the shifter to hit the side of the console. Something isn't bolted up right or the transmission is shifted toward the driver's side of the car somehow. If it shifts fine with the console out, the linkage is ok. Is it possible the shifter is bent?
Maybe the lever at the bottom of the shifter that actually engages the linkage levers to move them back and forth is bent sharply to the driver's side, forcing you to have to move it too far to the left to engage the linkage below.
Old Sep 20, 2008 | 08:26 PM
wro87's Avatar
wro87
good luck...69VETT
The interlock cable is off at both ends that was my first thought? But what really bothers me is that we could not move it over 1st/2nd without removing the trim plate and then we still hit the side. The motor mounts and the trany mount look ok but I will look into that even more. Can the trigger pin give you enough trouble to keep it out of 1/2?
Thanks wro87
Old Sep 20, 2008 | 09:37 PM
PeteZO6's Avatar
PeteZO6
The shift lever bolts into the shifter "pivot assembly" for lack of a better term. Check that it's bolted together properly. My '69 shifter has always rubbed against the console in reverse since I bought it at 2,500 miles. So it's tight even when assembled correctly.
Cheers,
Pete
Old Sep 21, 2008 | 01:19 PM
69Vett's Avatar
69Vett
also the 2 attachment points where the shifter bolts to the mount,
frequently breaks loose, make sure the bolts will tighten down good and tight,
you are referreing to a stock shifter ? Correct, ? not a Hurst or another type.
you might loosen the bolts for the shifter mount and see if you can get some extra space distance, by shifting the mount over slightly.
The corvette shifter does not mount to the tranny, but is is close to it.
I just looked at mine, there is a space of app. 1/4 -3/8 between the shifter mount and the transmmission. good luck ...69VETT
Old Sep 21, 2008 | 11:01 PM
wro87's Avatar
wro87
GOOD throught it is a stock shifter now and it looks like the PO might had installed it for we found a OLD HURST shifter with the White shift **** but no linkage. Could he possiblly removed the shifter and bolted the t-handle in place of the Hurst stuff. Tring to bolt a GM to the hurst linkage I would not have thought it would work will start to look into that also. Thanks wro87
Old Sep 22, 2008 | 12:19 AM
69elky's Avatar
69elky
I do not think that you can use the Hurst linkage with an intermix with the stock linkage. I have never tried to,but they are different. You have something else going on with your stock shifter.
Old Sep 22, 2008 | 10:09 AM
hugie82's Avatar
hugie82
Just a thought... Make sure the trans mount is still in one piece! It can move the trans over just enough to cause a problem like that.
Old Sep 22, 2008 | 09:15 PM
69Vett's Avatar
69Vett
A Hurst handle will not bolt to a stock shifter,
Here is a stock configuration,
Old Sep 22, 2008 | 09:41 PM
72LS1Vette's Avatar
72LS1Vette
Also check the E-clip at the left side of the pin that holds the shifter assembly together. The shifter on my 72 was really sloppy and I found that the E-clip was mangled and almost falling off. You have to squeeze the bracket together with a vice grip to get a new clip in but a little effort and $.24 at the hardware store resulted in a much tighter shifter.
Rick B.
Old Sep 26, 2008 | 01:34 PM
wro87's Avatar
wro87
OK Gang Heres an Update!!
Got the Car up on the Lift last night and finally able to look up to see whats going on. The rear trany mount is pretty well shot is craked and about 1/2 as thick as the new poly one we have for replacement. On the linkage it seems that most of the holddown pins have been replaced with cotter keys and some of the shimes are missing on both side of the linkage.
Now where can I buy some shimes and tranny clips? Can I just use some SS shim material and better cotter keys and can I really change them out with out pulling the tranny (Looks to be a real PIA some of the exhaust is welded) or can I change them all out with out pulling it.
Thanks again Gang WRO87
PS on the fornt of the tranny there seems to be some type of switch I found a smashed spad on a wire hangin but would the swith have a slip on spad or a bolt on is this the TRC switch?
To shifter linkage??
