Changing Horn button
Old Sep 22, 2008 | 11:33 AM
Derby98's Avatar
Derby98
St. Jude Donor '09
Default Changing Horn button
I am trying to replace my horn button on my 71. How the heck do you get it off the steering wheel?
I figured I'd ask you fellas before I break something!
Old Sep 22, 2008 | 11:38 AM
7T1vette's Avatar
7T1vette
It just snaps on. Usually, if you use both hands (fingers, anyway), you can pull out on both sides at once and the button will come off. If it is really tight, you can put a screwdriver on each side [in the gap under the button] and gently pry. It should pop off pretty easily.
Old Sep 22, 2008 | 12:05 PM
Derby98's Avatar
Derby98
St. Jude Donor '09
Thanks, I assume it snaps back in the same manner?
Old Sep 22, 2008 | 03:51 PM
Alan 71's Avatar
Alan 71
After you get it off you'll see the little prongs that hold it on and you'll know how hard to hit it with your hand to pop it back on.
Regards,
Alan
Old Sep 22, 2008 | 04:27 PM
Derby98's Avatar
Derby98
St. Jude Donor '09
Thank you Alan
Ben
To Changing Horn button
