vac. relay
Old Sep 25, 2008 | 05:01 PM
ripforrey's Avatar
ripforrey
Default vac. relay
Pulled relay's from 76 to bench test. I can put vac. on metal port and the valve moves and holds vac. spings back to normal when vac. removed. I can't seem to get vac. form either outlet port on relay.
Am I correct in assuming that some sort of "O" ring(s) on stem is bad for both relay's?
Thannks
Old Sep 25, 2008 | 05:05 PM
...Roger...'s Avatar
...Roger...
Put vacuum on the large center port...vacuum should come out either the top or bottom large port depending on the vacuum on the small top port
Old Sep 26, 2008 | 06:07 PM
ripforrey's Avatar
ripforrey
Took the relay apart. I figured I was going to buy another if I wrecked this one anyway. Both were just gummed up with dirt. They both seem to be working now. When I get the boots for the actuators I'll try them out.
To vac. relay
