New Valve Covers
Sep 30, 2008 | 05:22 PM
8th Gear
New Valve Covers
I need to replace the gaskets on a 74 350 and it has been suggested that I should consider some more ridgid covers. I would appreciate your recommendations. Thanks
Sep 30, 2008 | 05:39 PM
These valve covers always look good on a
Shark Car ... They are often for sale in the C3 Parts for Sale section and frequently at reasonable prices.
You can also pick them up from most of the
Forum vendors for about $250.
http://www.zip-products.com/Zip/prod...B44FF42E1FA2DD
Good luck...
GUSTO
Sep 30, 2008 | 09:07 PM
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
We have these currently on our forum special section too!
112.00 per valve cover, here is the link:
http://willcoxcorvette.com/advanced_...ds=valve+cover
Willcox Inc.
Oct 1, 2008 | 03:43 AM
i like these...
Oct 1, 2008 | 04:07 AM
I love the Edelbrock Elite Series valve covers ( with or without logo ) :
More pictures by clicking on "My Corvette Photos" on the left...
Oct 1, 2008 | 09:23 AM
Quote:
Originally Posted by
gingerbreadman1977
i like these...
That is what I have on mine too. Spendy but nice.
Oct 1, 2008 | 02:18 PM
The stock stamped valve covers will seal fine... IF you make sure the sealing surface (rail) is nice and flat and you use a composition gasket...like a Fel-Pro type. Most stamped covers leak because the bolts have been overtorqued [in an attempt to make them seal better] and the seal surface is deformed around the bolt holes. Put the cover on a flat, hard surface and use a piece of steel with a flat end to smooth out the 'lumps and bumps' on the gasketed surface.
Oct 1, 2008 | 04:19 PM
2017 C3 of the Year Finalist
Hey gingerbreadman, where 'd you get those plug wire seperaters? Exactly what I'm looking for!!
Oct 2, 2008 | 03:17 AM
jbaron
Pm sent your way
Oct 2, 2008 | 11:06 AM
Nice USA-made wire looms & separators here also:
http://www.made4uproducts.com/wire_looms.htm
likely asian: cheap new knockoffs fleabay item 170256047280
likely asian: new right decent tall cast aluminum valve covers on fleabay; delivered for under $55: fleabay item 370090613001
None of that stuff is mine ... FYI only
Oct 2, 2008 | 08:21 PM
Thanks for the orders guys.
Willcox Inc.
