Piston and Rod Combos
Old Oct 5, 2008 | 10:35 AM
  #41
Deakins's Avatar
Deakins
To answer your original post; at those levels you can get by with about any forged 4340 H-beam connecting rod and KB hyper piston. KB hypers have a bad reputation mostly due to engine builders not taking the time to set them up properly and then work on what you can and can't get away with. Doing our job properly, we have disproven all the "can't do's" that we have read about.
When you look at the Carrillo K1 connecting rods keep in mind that these are not the Carrillo rods that you may have heard about in the past. The ones we have used on sprint car engines cost around $2500 depending on the bolts installed. I'm not saying that they K1's are not a good part for the money; I'm just making sure that you understand you will not be buying their top shelf connecting rod.
As for making over 500hp at 7000 RPM with a 355; it's totally possible and really not too difficult if you have the budget. About every cylinder head manufacturer and magazine out there have put together engines that pulled that much and more with modern camshafts and cylinder heads.
Old Oct 5, 2008 | 10:40 AM
  #42
Guru_4_hire's Avatar
Guru_4_hire
Cruise-In IV Veteran
Cruise-In V Veteran
I expect that the K1 rods are at least as good as SCAT rods. At least K1 advertises their weights.
I am not exactly making a NASCAR or F1 engine here.
Old Oct 5, 2008 | 11:14 AM
  #43
billla's Avatar
billla
St. Jude Donor '14
Originally Posted by Guru_4_hire
Dont mind me.
I am all about hearing what you have to say. Just sayin how I got to where i was.
Absolutely no offense meant or taken. I've just learned that I have an approach that doesn't work for every situation, and in those cases I more get in the way than help. It's all good
Old Oct 5, 2008 | 11:47 AM
  #44
Guru_4_hire
Cruise-In V Veteran
Coolio! Have a great afternoon.
Old Oct 5, 2008 | 11:56 AM
  #45
Little Mouse's Avatar
Little Mouse
Are you going to run a one piece seal crank.
Old Oct 5, 2008 | 11:59 AM
  #46
Guru_4_hire
Cruise-In V Veteran
Yes sir! It came in the mail yesterday.
Old Oct 5, 2008 | 12:23 PM
  #47
Little Mouse
Ok Sir, call me as-hole Jim about anything but sir lol.
Guess its to late now to talk you into the cast steel
one piece, internal balance 3.75 crank. Its not very
expensive, if I remember right believe motorhead used
one in his 550hp 406.
Old Oct 5, 2008 | 12:28 PM
  #48
Guru_4_hire
Cruise-In V Veteran
I got the same speech on the use of Ma'am.
I got a sweet deal on a GM forged crank.
Old Oct 5, 2008 | 12:54 PM
  #49
Guru_4_hire
Cruise-In V Veteran
I have 3.55s at the moment. I am considering 3.9 or a 4.11.
with the M21 I have if I set the redline to 7000rpm even with the 4.11s I can hit 60 in first gear.
I am leaning towards 3.9 because I can still use my 3 series carrier and have it rebuilt.
Old Oct 5, 2008 | 12:59 PM
  #50
Little Mouse
Is your 3.55 rear in good shape.
Old Oct 5, 2008 | 01:02 PM
  #51
Guru_4_hire
Cruise-In V Veteran
Havent had a problem with it.
Old Oct 5, 2008 | 01:13 PM
  #52
Little Mouse
3.90 X 2.20 = 8.58, 3.55 X 2.64 = 9.37.
3.55 is nice compromise gearing still pretty good on the freeway,
a 2.64 low super T-10 around $500 will pick up a good used one,
you will have that much in redoing your rearend.
Old Oct 5, 2008 | 01:14 PM
  #53
63mako's Avatar
63mako
St. Jude Donor '08-'09
You asked for opinions. There is no way I would even consider a Hyper piston in an 11.5 to 1 motor that will be running 7000 rpm.
Old Oct 5, 2008 | 01:27 PM
  #54
Guru_4_hire
Cruise-In V Veteran
Wouldnt the long duration camshaft like the higher RPMs on the highway?
This is what Crane says about the cam
ROUGH IDLE, PERFORMANCE USAGE, GOOD MID-RANGE HP, MILD BRACKET RACING, AUTO TRANS W/3000+ CONVERTER, 3800-4600 CRUISE RPM, 10.0 TO 11.5 COMPRESSION RATIO ADVISED. BASIC RPM 3000-6500
My Highway RPMs would be 2400-3300rpm.
Old Oct 5, 2008 | 01:28 PM
  #55
Guru_4_hire
Cruise-In V Veteran
That is definitely a good thought.
That leaves me with Ross low dome and 5.7" rods.
Old Oct 5, 2008 | 01:40 PM
  #56
Little Mouse
long duration will help relax the engine on the highway but you really have the perfect comprimise gearing. the 2.64 low super T-10 would lower 1,2,3 gearing, there is more then one way to skin a cat if you don't have a long stroke engine for torque the lower gearing in the trans will give you more torque also help the engine climb up into its best power band quicker. if you change to 3.90 you ruin some of your highway capabilities and the overall ratio would not be as good in the first three gears with the close ratio trans 3.90s as would be with the wide ratio trans 3.55s.
JustinD bought a good wide ratio 2.64 super T-10 off a forum member.
Old Oct 5, 2008 | 01:56 PM
  #57
Guru_4_hire
Cruise-In V Veteran
There are a couple on ebay now. When I get ready to buy a transmission I should readily be able to find one.
To Piston and Rod Combos
Old Oct 5, 2008 | 01:58 PM
  #58
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
There is also a 2.88 first gear Super T10, I had one in my '80
There is supposed to be a 3.44 to but I have never seen one
Old Oct 5, 2008 | 02:38 PM
  #59
Little Mouse
Don't go to wide on the ratio spreads your only going to have a 350
a little on the cammy side to pick up the spreads.
9.37 low gear is pretty good not far off that 10.00 magic number lol.
Old Oct 5, 2008 | 03:54 PM
  #60
Guru_4_hire
Cruise-In V Veteran
Interestingly enough the drag2000 has the car doing the 1/4 mile faster with the Super T10 and a 3.55 rearend than a Muncie M21 and a 3.9.
10.573 versus 10.619
