Carb Question
Old Oct 6, 2008 | 12:45 PM
95AquaVette's Avatar
95AquaVette
Default Carb Question
I found on our 78 there is a push button type switch on the drivers side of the carb it look like it should be actuated when the throttle is closed. But the throttle does not touch the switch. Is this something that needs to be fixed and what is that switch for?
Tony
Old Oct 6, 2008 | 12:57 PM
SanDiegoPaul's Avatar
SanDiegoPaul
From: San Diego - Deep Within The State of CONFUSION!
Tony
Sounds like electronic kickdown. Is it a four-speed or automagic?
Shoot us a picture.
Old Oct 6, 2008 | 01:11 PM
95AquaVette
Its an automatic.
Old Oct 6, 2008 | 01:39 PM
SH-60B's Avatar
SH-60B
Maybe it's the A/C solenoid. When the A/C is on it bumps up the idle to compensate for the drag the A/C compressor puts on the motor, so it won't stall at idle. Turn on the A/C and see if it extends.
Old Oct 6, 2008 | 02:41 PM
1nicecorvette's Avatar
1nicecorvette
i have the same thing on my 79. it looks like a gold colored plunger and it moves freely in and out.
Old Oct 6, 2008 | 07:37 PM
jakesindy's Avatar
jakesindy
Default ac
Thats for the ac when you turn on the ac it jumps up the idle If its a L48 500 rpm in gear and 600 rpm in gear with the ac on The brass bolt head can be ajusted in or out like a bolt
Old Oct 6, 2008 | 08:52 PM
thegazman's Avatar
thegazman
Default thegazman
Chris is right...that switch is for your A/C. With the A/C off the plunger should not touch the accelerator. Turn the A/C on and adust the switch to maintain your idle under load from the compressor.
To Carb Question
