Ive installed the new door panels on my 1968 and the inner portion of the window trim just arrived...the chrome piece with the felt on the inside that touches the window. My question is, how and what do you attach it to?? The trim piece looks like it has holes in it for screws, but theres nothing for it to screw into. Does it attach directly to the edge of the inner door panel? If so, how does it stay attached?
Hi FN30,
On the repro 71 door panels that I've seen there is a piece of thin aluminium angle along the whole top of the door panel. On original door panels this angle was fiberglass. All original sealing strips and some repro sealing strips are stapled to the angle. Some repro panels have the sealing strip pop-riveted to the angle.
Regards,
Alan
PS: I know the 68 panel looks quite diiferent but perhaps the sealing strip is handled the same.
Not on 68`s, no one have I found makes a accurate window whisker for 68`s. The whisker attaches to the door. I believe Paragon is the company that I used.
The door panel is installed bare except for the door handle hardware.
the car used to have ugly 2-tone black and white '75 door panels on it. I replaced those with original '68 pieces and as was mentioned above, the inboard piece on the '75 was actually bonded to the door panel. On the '68, its a seperate piece. Even if the piece was attached directly to the edge of the '68 door panel, it would still leave quite a gap. Ill try to post pics later to explain what Im talkin about.
Thanks for the help
I think you may have the exterior trim.The inner if my memory is correct attaches to the door itself with hexhead bolts.Ialso don't remember any chrome on the inner and the whiskers are attached to a fairly heavy piece of steel strip were the outer is only the whisker,felt and chrome.
Dave
If I remember correctly the wiskers that rub along the inside of the window are actually attached to the door frame. You will have to take the door panel back off the door, then with the window in the down position you can place the wiskers on the door frame. I am going on memory here and it has been a while since I replaced mine but I think that is the way it is done.
wayne h.
The 68 door panel uses a 2 piece inner seal, another one year item that to my knowledge isn't reproduced.
The whiskers attach to the rubber seal which attaches to the frame of the door.
I'm holding off installing my new door panels until I find the rubber seal for my passenger door. Here's what the OP is looking at.
Well, that would explain it...so now the question is where do we find an aftermarket rubber seal?? I couldnt even reuse the old one because the door panels I pulled off were 1975 pieces
I guess we can only look for used parts at this point. I bought 2 complete 68's and only have 1!!
I may take mine apart and see if I can make myself something that will look decent. I really want to redo my interior.
If you find any for the passenger side above and beyond what you need please keep me in mind and I'll do the same for you.
Goodluck,
Rick
Rick...I may have just found what we are both looking for...Corvette America in Williamsburg Virginia has "1968 Inner Seal Assemblies" "Includes left and right upper metal supports, left and right door window felts, and left and right rubber door panel seals." The 6 piece set is part #40430 68 and lists for $209.99. I bought seat frames from the guy and he sent me one of their catalogs.
Something else of interest, they also sell a "Door Panel Mounting Kit" which looks like it includes 4 brackets and 8 screws. How do you guys have your door panels mounted to the door?? When I bought my car, the panels on it had screws with caps on them going right through the panel at all 4 corners. It was a B!tch to get the new ones to line up properly and Im wondering now if it was just some jury rigging on the part of the previous owner.
I'll check out Corvette America, thanks for the heads up and the part number.
I haven't been looking actively lately but it's good to hear someone is reproducing these now. I guess I just ran out of excuses, now I've got to get going on my interior resto.
As far as mounting your panels, buy the kit. There's no doubt that the previous owner jury rigged the ones you've got.
yea...not real hyped about spending 200 bucks for a piece of rubber!! So how exactly do you "properly" mount the door panels with those brackets??
I'll dig out my assembly manual this weekend and see if I can post a picture showing how the panel mounts, if not I'll be removing mine soon and can take some pictures then.
BTW, can you post links to the stuff you found at Corvette America? I can't seem to find the parts you listed.
Its not Corvette America, Virginia Vettes is in Williamsburg Va.
yea, sorry bout that...the catalog says corvette america but theres a sticker that says Virginia Vettes on it. The address is 105 Lindrick St. Williamsburg, VA 23188. 757-229-0011 email is sales @virginiavettes.com
Like I said, I bought reconditioned '68 seat frames from them and they had excellent customer service...they actually mislabled them on ebay as 1100 bucks when I guess they were supposed to be labeled as 2100 like their other reconditioned seat frames. Because it was their error, he actually sold them for me as they were listed. Anyway, if you end up ordering that trim kit, let me know how it works out for you. Mines going into storage this weekend because Im headed back to the desert next month, but once I get home this summer Im finnishing the interior resto and contemplating a ZZ427 crate motor.....
Fly Navys second above picture is accurate for a 68. The inside whisker attaches to the metal door frame with screws and is adjustable in and out for the window.
The window side has the whisker and then the door panel slips under a rubber strip the full length of the panel .
There are 2 metal clips that are inserted into the back of the panel at the corners and screw into the edge of the door near the weather strip. Two screws at the top corners are the only ones that are actually go through the door fabric. The rest is help by matching the push together locking strips. ... you`l need some..
Blue68 & Irincross are correct
The inner whiskers attach to the door panel with screws.
The chrome is on the outside whiskers, not the inside. You will have to remove your inner door panels to correctly attach the inner whiskers to the metal door frame.
I have had my 68 since 1972 and when I did my restoration, that is how they were attached.
You might try Paragon or Dr. Rebuild for the correct ones.
I can't remember where I got mine since my restoration project took 10 years to complete.
Kurt
