Compression check................
Old Oct 17, 2008 | 12:24 PM
imariver's Avatar
imariver
Default Compression check................
I have the exhaust manifolds off my 73, 350 automatic, so now would be a good time to check compression. Engine has a little over 100K on it original, never apart and will be cold. I have done compression checks before, but I was just wondering if there were any tips, tricks and or advice?
Old Oct 17, 2008 | 12:49 PM
Durango_Boy's Avatar
Durango_Boy
Unplug the power wire to the distributor.
Leave all plugs in while doing them one at a time.
Make sure you let the engine crank at least five times per reading.
Write down the findings.
If you get any lower than average readings, squirt oil in the hole and re-do the test on that cylinder and compare readings.
Old Oct 17, 2008 | 12:59 PM
DRIVESHAFT's Avatar
DRIVESHAFT
Gotta disagree with a bit of what DB wrote above.
All spark plugs should be out & the carburetor should be wide open.
I know the way you said will work but it isnt the correct way to do it.
Old Oct 17, 2008 | 01:11 PM
Durango_Boy
Why exactly? That's how I was taught, and I was told that you wanted the engine conditions to be almost the same as when it's cranking over to start. That would have the plugs installed and the carb as it would be at idle with a cold choke.
Why would you want the plugs removed and the throttle wired open?
Old Oct 17, 2008 | 02:06 PM
imariver's Avatar
imariver
Hummmmm......... Interesting, I would have guessed that all the plugs would have to be out. Would compression on the other seven cylinders influence the reading on the eighth due to slower cranking speeds?
Old Oct 17, 2008 | 03:12 PM
LB66383's Avatar
LB66383
That's how the specs are determined -- at a certain cranking speed range that you get with all of the plugs out and the carb wide open. If you do it with the plugs in and carb closed, the engine won't crank fast enough or pull in as much air. You'll get lower compression readings than spec and think the engine is going south.
Old Oct 17, 2008 | 03:20 PM
DRIVESHAFT's Avatar
DRIVESHAFT
Yeah, what he said
I know it wont make or break the test, but it is the "correct" way.
Old Oct 17, 2008 | 03:42 PM
dmaaero's Avatar
dmaaero
adding oil to a bad ( low compression) cylinder will tell you whats going on in there
Old Oct 17, 2008 | 03:46 PM
DRIVESHAFT's Avatar
DRIVESHAFT
Originally Posted by dmaaero
adding oil to a bad ( low compression) cylinder is not going to help you much either.......
Oil in the cylinder helps to locate whats leaking.
If oil raises your compression, you have bad rings.
If oil doesnt change the readings, your valves are probably leaking.
Old Oct 17, 2008 | 03:57 PM
dmaaero's Avatar
dmaaero
thanks for the info, i"m still learning. I changed the incorrect info
Durango_Boy
I didn't think the goal was to see how 'high' the compression numbers were, since there is no baseline for comparison...just to make sure the cylinders all have 'similar' compression numbers. I mean, if I someone were to ask you what their compression 'should' be with a 100K engine that was virgin...how can anyone say, without knowing it's maintenance history or complete driving style history...what the compression should actually be. I don't think an average of 130 would mean much compared to a higher number of 150...would it?
Old Oct 17, 2008 | 06:17 PM
7T1vette's Avatar
7T1vette
The Chevy Service Manual does provide a baseline for its engines. Plugs out and carb wide-open....
Old Oct 17, 2008 | 06:21 PM
RMS73's Avatar
RMS73
I think LB66383 meant to say 'going North'.
Roger
Old Oct 17, 2008 | 07:30 PM
Edzred72's Avatar
Edzred72
That's the way Lars did it on my 'ol 350
Eddie
Old Oct 17, 2008 | 07:43 PM
Durango_Boy
Eddie
If I'm wrong I'll certainly concede to the proper way...I just would like to know the specific reasons why. Getting more air in and getting higher readings is one thing, but why is that important if you still get an average the other way and you can see if any are specifically lower than the others?
Reggie Dunlop's Avatar
Reggie Dunlop
As stated above - you remove all of the plugs so that the engine will crank easier, faster, and at a consistant speed. The carb gets blocked open because you need to supply the cylinder with air. All GM service manuals (Doge and Plymouth too) specify this method.
Old Oct 18, 2008 | 10:39 AM
RMS73's Avatar
RMS73
A leakdown test is a better indication of cylinder 'health' than a compression check. Takes a little longer, but you get what you 'pay for'.
I have done both when checking my engine.
Roger
To Compression check................
Old Oct 20, 2008 | 08:01 AM
imariver's Avatar
imariver
All very good answers and information, thanks. I did do the compression check over the weekend and as stated above, the engine was cold and hasn't been started for a couple of weeks. Both manifolds were off so it was quite easy to get this done.
On the very first compression stroke on each and every cylinder the compression shot up to 90psi. The lowest reading I obtained was 164 psi and the highest reading was 178psi. I did the test twice, with the plugs in and with the plugs out and give or take a pound or two, ........ the readings were the same, even the initial 90psi Now if I'm not mistaken the service manual says that the compression is suppose to be 160psi. Again, the engine has well over 100K on it and has never been apart. Anyone have any comments or thoughts on this?
Old Oct 20, 2008 | 08:04 AM
7T1vette's Avatar
7T1vette
It appears that your engine is in pretty good shape, for its age.
Durango_Boy
Those are good readings.
Did you try squirting any oil in the lower reading cylinders and trying it again? Sometimes a compression check can shed light on a valve seat problem. Go ahead and post the readings per cylinder in a list.
Next try a leak down test per cylinder, and compare the notes from the two tests.
