Why would someone do this
Old Oct 18, 2008 | 06:52 PM
Oldguard 7's Avatar
Oldguard 7
Default Why would someone do this
Two weeks ago while I was tuning my vette, the vehicle dies while idling and there was a plume of white smoke which followed. Here is the picture of the light green wire that was spliced into the pink distributor wire. I have no headlights, lights or any accessories working. The car is dead.
Old Oct 18, 2008 | 07:02 PM
Alan 71's Avatar
Alan 71
Hi O7,
I believe strongly that BUBBA does his best work on things electrical.
Regards,
Alan
Old Oct 18, 2008 | 08:24 PM
weimer20's Avatar
weimer20
Originally Posted by Alan 71
Hi O7,
Regards,
Alan
Old Oct 18, 2008 | 09:11 PM
...Roger...'s Avatar
...Roger...
This thread with the green wire sounds familiar.
Old Oct 18, 2008 | 10:34 PM
Oldguard 7's Avatar
Oldguard 7
Yep it is me. The full story is under the car dies along with everything else thread. I just learned how to post pix on the forum and I mentioned in my previous thread that I will post a pic of this. I just dont fathom why someone would do this. I have not checked for power to any thing yeet as I dont have much time to look at at. Pretty wierd huh?
Old Oct 19, 2008 | 03:04 AM
RogieStone's Avatar
RogieStone
Hey we must have bought our cars from the same guy.
Old Oct 19, 2008 | 10:33 PM
Red70vette's Avatar
Red70vette
Yours is not to reason why Bubba did things. There is no rhyme or reason with Bubba. Looks is not an issue, safety is not an issue, function is not an issue, with Bubba there is no issue that means anything.
Old Oct 19, 2008 | 11:18 PM
A8skyhawk's Avatar
A8skyhawk
My personal favorite is finding the brown extension cord cable randomly spliced in for no apparent reason...
Old Oct 20, 2008 | 12:44 AM
myoriginal77's Avatar
myoriginal77
2 quarters stuck into the radio fuse cost me the behind the dash harness on my 75, I'm not sure what their amp rating is but it's a lot ....
Frank
Old Oct 20, 2008 | 02:56 PM
Bowerss2's Avatar
Bowerss2
Originally Posted by Oldguard 7
Two weeks ago while I was tuning my vette, the vehicle dies while idling and there was a plume of white smoke which followed. .
Could be a Lucas electric wiring harness
seriously, if you work on British cars, you get used to this kind of thing, not from bubba, but from the factory.
As they say Lucas electric invented the intermittent headlamp
Old Oct 20, 2008 | 04:00 PM
Oldguard 7's Avatar
Oldguard 7
I found the where the green wire went to the possible cause the short when I took the time to really look at it. The green wire was from the electric choke. I took the vehicle to a repair facility back in Feb 2004 to have the electric choke wired. The technician had spliced wire from the choke into the pink power feed wire to the dizzy. I noticed part of the green wire from the choke was crushed between the dizzy hold down clamp and the intake manifold (my fault for not making sure that the wire was routed around the dizzy hold down clamp) and it shorted out against the manifold burning the insulation off of the green wire. Since the vehicle was running and with the choke wire spliced to the power feed wire being hot would cause the vehicle to stop running. Once I get the vehicle running, I will not use the electric choke. My question is could that technician have run the wire directly to the fuse panel using one of the accessory spaces on the box or some other way?
Old Oct 20, 2008 | 04:39 PM
Brooklinite's Avatar
Brooklinite
.... My question is could that technician have run the wire directly to the fuse box using one of the accessory spaces on the box or some other way?
Sure. But that would have taken longer. What a tool.
Old Oct 20, 2008 | 04:55 PM
speedreed8's Avatar
speedreed8
you may already know this but, without the power wire to the elec. choke, its going to close the choke butterfly and stay closed. the 12+volts slowly opens it ,without it, you will have to loosen the perimeter screws on the choke housing and turn it until the choke butterfly is full open, of course doing this when the car is cold. and that should lock it open. good luck.
Old Oct 20, 2008 | 08:14 PM
rayluka's Avatar
rayluka
Frank
Im gonna guess 200 amps
Old Oct 21, 2008 | 05:18 AM
SH-60B's Avatar
SH-60B
Yes, as long as it's only hot with ignition "on".
Old Oct 21, 2008 | 09:12 AM
Vette79C3's Avatar
Vette79C3
Geez, I thought this would of been common sense routing it properly to the fuse box. I hope you go back to the shop and have a talk with this technician in disguise...LOL.
Old Oct 21, 2008 | 10:25 AM
DC3's Avatar
DC3
This is important.
Old Oct 21, 2008 | 11:10 AM
moosie982's Avatar
moosie982
There is no such thing as "common sense" when you deal with bubba weather he does it as a job or for himself if he owns the car.. Peace,,,Moosie
To Why would someone do this
