Easy way to remove headlight switch??
Old Oct 18, 2008 | 10:27 PM
wro87's Avatar
wro87
Default Easy way to remove headlight switch??
IS there any easy way to remove the headlight switch (71' coupe)without taking all the dash out.
Thanks Gang wro87
Old Oct 19, 2008 | 12:01 AM
Red 71's Avatar
Red 71
From: Melbourne, Fla. 6 months- New Middletown, Ohio 6 months
On my 71 I just remove the top dash pad and it is right there.
Old Oct 19, 2008 | 05:37 AM
LYLE's Avatar
LYLE
If you take all the screws out of the LH dash pad and the two bolts out of the steering column you can pull the LH side of the dash out and have a little room to get the switch out. Do not pull the dash out any more than is needed as the wiring is hooked to the dash pad.
Old Oct 19, 2008 | 08:30 AM
...Roger...'s Avatar
...Roger...
But it only takes a couple min. to remove ALL the screws across the front of the dash leaving the 2 inside the door jamb holding the right side dash.Removing the extra screws will allow enough flex to make things easier and hopefully not break the center cluster frame.
Old Oct 19, 2008 | 09:13 AM
Durango_Boy's Avatar
Durango_Boy
That's how I first did it.
Old Oct 29, 2008 | 09:10 PM
prostreeter's Avatar
prostreeter
Default lightswitch
just did exactly what lyle said on 10/19 took half hour total.
To Easy way to remove headlight switch??
