I am going to put the car up on jack stands and have a look underneath. Has anybody used POR-15 on thier corvette frame? If so what was the end result. What else can be done to clean the frame and protect it?
Hi G427,
There are may threads about how various folks have treated their frames. Have you done any kind of a search?
What are you trying to accomplish and what sort of 'look' are you aiming for?
Regards,
Alan
PS: Here's the frame from my 71. It was powder coated and then sprayed with Krylon #1613. I wanted an 'original' but 'a little nicer' look.
POR is a great product. I used my 2000 psi pressure washer to clean my frame. It took everything off down to the bare metal. Those steam pressure washers would work great also.
I have a 67 K20 plow truck I used it on. Some parts of the frame it work great others peeled, bubbled and rusted under paint BAD. I went to there office here in Jersey and I was told I cleaned the metal to well WTF!!!! He then told me I had to buy their primer AND before anyone jumps in.....YES it did say in the directions new or clean metal should be primed first. I'm sure your vette will do better than a Jersey plow truck!
It starts about the floor pans, but there's several post between myself and a couple members about the frame. All the info you need to POR-15 your frame is in there.
