Timing chain hitting timing cover!
Old Nov 11, 2008 | 08:49 PM
one-72's Avatar
one-72
one more thing.If you install it without proper clearance the cam gear will eat the front of
t
he block.If you allready damaged the block face behind the gear it can be repaired by milling and installing a brass insert.I made a repair like this on a BB boat engine 12 yr,s ago
it,s still running .good luck.
