Door spring help
Old Oct 28, 2008 | 11:22 PM
jagan's Avatar
jagan
Default Door spring help
Is it possible to replace the driver door hinge spring without taking the door off? I put new springs on with the doors off the car and now the drivers side has poped out of postion. This job was a piece of cake with the doors off.
Old Oct 28, 2008 | 11:26 PM
...Roger...'s Avatar
...Roger...
Yes but there is a tool you need or will have to make.Just be very careful because its easy to chip the door edge.
edit- http://willcoxcorvette.com/product_i...ducts_id=25646
Old Oct 28, 2008 | 11:30 PM
Angel303's Avatar
Angel303
Check this out:
https://www.corvetteforum.com/techti...D=67&TopicID=3
You will need a special tool which is simply a bent screw driver. You can get it from Ecklers for $10.00:
http://ecklers.com/product.asp?pf_id=A4300&dept_id=120
Good luck
Old Oct 28, 2008 | 11:32 PM
jagan's Avatar
jagan
I have seen this tool many times. I am guessing that you just pry the darn spring back into the cut out areas on the hinge.
Old Oct 28, 2008 | 11:35 PM
jagan's Avatar
jagan
Sorry, jut saw the tech tip. Thanks!
To Door spring help
