pvc valves
I have always used an orginal PVC even for modified motors.
L36 427ci, 390hp Engine
L68 427ci, 400hp Engine
L71 427ci, 435hp Engine
L88 427ci, 430hp Engine
They use different pvc valves. (numbers on the pvc valves are different) Pretty easy so far right, just pick out which engine you have. Unless you have modified one of those engines !
If you put the wrong pvc valve in a engine, an it does not open an close at the right time, would that not affect performance and mileage. If your crankcase is not properly vented, would that not allow gunk build up inside there, not to mention make it prone to oil leaks. One would assume, since those engines have different hp ratings, they also produce different vacume levals.
1966 corvette
427 ci 390hp 10.25:1 cr hyd cam, oval port heads, Q-jet carb, uses a pvc valve marked #2
427 ci 425hp 11.00:1 cr solid lifter cam, rect port heads, holley carb, uses a pvc valve marked #6
both have straight vacume line hook ups, seems to me the differance would be the spring tension inside the valve.
In my case, 1974 has 2 different pvc valves listed. one is for a high performance engine, 250hp the other is for non high performance engine 195hp both are 350"s. I now have right at 390 hp what pvc valve would i need? One for a 390hp engine or one for the correct vacume that my engine produces? Thoughts please
I just came from the chevy dealer, for my 74 the non hp valve is marked E, the hp valve is marked K. The high performance valve deffently has a weaker spring in it. I have spoke to several parts people, an so far no one even knew they were marked !
Pick one for the brand (GM/Chevy, I assume) and size (cu. in.) engine and configured to fit and connect as your 'plumbing' allows.
