Does your's do this??
Old Nov 4, 2008 | 12:33 AM
chvet73's Avatar
chvet73
I ruined a radio with hardware store fittings and a copper line. Got a complete kit from ZIP and have had no problems in the last 8 years. From my experience only the factory fitting works on the gauge end.
Old Nov 4, 2008 | 06:37 AM
nutsy's Avatar
nutsy
no leaks here.
Old Nov 4, 2008 | 01:57 PM
DC3's Avatar
DC3
I believe you are right about this. Since the gauge is designed for a compression fitting, I ended up rigging a small length of copper tubing and a ferrule inside the fittings I found to make sure it would work.
This Auto Meter kit from Summit contains the correct fittings.
http://store.summitracing.com/partdetail.asp?autofilter=1∂=ATM-3229&N=700+400442+4294846127+115&autovie w=sku
The link is for the 4' version. They also make a 3' and a 6' kit. And you can get a -3 AN in all three lengths instead of the -4 AN.
Next time I'll go that route.
DC
Old Nov 4, 2008 | 04:48 PM
RunningMan373's Avatar
RunningMan373
Best bet is to replace the gauge with an electrical one with a sender. On my 'to do' list. C.
Old Nov 4, 2008 | 05:31 PM
TERRY CLARK's Avatar
TERRY CLARK
Just cut the end off and reuse ( if you have enough )....make sure it is straight up when you tighten it !
Old Nov 4, 2008 | 08:11 PM
Flying Low's Avatar
Flying Low
The plastic tube should have a small brass tube inside to support it when the ferrul is tightened. This gets overlooked a lot of times, without it plastic tube collapses and leaks.
Old Nov 4, 2008 | 08:17 PM
hammadown's Avatar
hammadown
Good point Mine could be missing, thanks for the tip....
Thank you......... to all that posted...... if I knew about this info before I would have changed the line out when I had the motor out.
Hammadown
Old Nov 5, 2008 | 02:21 PM
sly vette's Avatar
sly vette
Never heard of this before. Can anyone confirm this???
Sly
Old Nov 5, 2008 | 02:40 PM
dstaley's Avatar
dstaley
It's not uncommon, but I don't know if GM did it originally.
Old Nov 5, 2008 | 02:46 PM
Durango_Boy's Avatar
Durango_Boy
Where can one gets these little items? I have never seen or used one and I'll bet they make a huge difference.
Old Nov 5, 2008 | 02:50 PM
dstaley's Avatar
dstaley
My local hardware store has them, and I wouldn't be surprised if O'Reilly's (and other auto parts stores) also have them in the brass cabinet. I never had anyone ask for them while I worked for O'Reilly's, but they're there in ours. I saw them a couple weeks ago in the Everco brass section (behind the counter).
