Does your's do this??
Old Nov 2, 2008 | 11:02 AM
hammadown's Avatar
hammadown
Default Does your's do this??
72 350 base motor ............oil pressure line weeps but doesn't spill over
probably needs to be tweeked with a wrench but I cant seem to get one in that tight spot
Hammadown
Old Nov 2, 2008 | 11:04 AM
fugawi's Avatar
fugawi
mine leaks. i've tried new fittings new line. nothing seems to work. guess it's normal for these older cars..
Old Nov 2, 2008 | 11:39 AM
Durango_Boy's Avatar
Durango_Boy
I have seen those leak a lot. Usually the fitting was replaced a few times before it stopped, and yes, a stubby wrench with the end cut off was the only way to get in there and turn it. I think a Crow's foot worked too but that was after it had been done a few times.
Old Nov 2, 2008 | 11:45 AM
...Roger...'s Avatar
...Roger...
The best way I have found to fix it is replace all 3 pieces and buy them as a kit.
Old Nov 2, 2008 | 11:51 AM
Gordonm's Avatar
Gordonm
Replace the fitting in the block and the ferrel and nut. Probably one or all 3 are dinged up. No it should not leak. Most do though after a number of years.
Old Nov 2, 2008 | 12:36 PM
hammadown's Avatar
hammadown
Thanx guys... I guess im not alone
hopefully just needs to be tightened
Hammadown
Old Nov 2, 2008 | 01:53 PM
...Roger...
Hammadown
As you tighten,the ferrel will go deeper into the plastic line.Sometimes it will cut it,be prepared with new parts.One little tighten could ruin a planned outing that day.
Old Nov 2, 2008 | 03:01 PM
hammadown's Avatar
hammadown
You better believe it
Hammadown
Old Nov 2, 2008 | 03:11 PM
Greg73convertible's Avatar
Greg73convertible
So what line is better copper or plastic ?
Old Nov 2, 2008 | 04:04 PM
DC3's Avatar
DC3
My gauge line broke under the hood and I lost 3 quarts of oil before I knew what was happening. That would have been a hell of a mess if it had happened in the interior. Some guys have filled their stereos with motor oil when the plastic line broke inside.
For piece of mind, I replaced that POS plastic tube with a nitrous oxide hose from a speed shop. Less than $30. You might also do a search on the forum. Someone linked to a kit with a stainless braided hose like the nitrous hoses but it comes complete with all the fittings. I had to come up with the fittings on my own.
DC
Old Nov 2, 2008 | 06:56 PM
hammadown's Avatar
hammadown
DC
Thats a great idea must look nice and clean........and It's safer than that plastic line.
thats something I am going to do when I do my stereo over
Hammadown
Old Nov 2, 2008 | 07:21 PM
...Roger...
Don't give up on the plastic.There are some plastic lines that are just crap.I used to buy only from NAPA but have found on occasion their lines are brittle maybe because their old.Take your side cutters and pull the end out of the package and slowly cut the end and twist it around.If its crap it will cut easily.If its good stuff it will resist cutting,it will be tough and sorta rubbery.Good stuff will stretch also.Hope that makes sense.(not knocking the braided lines)
Old Nov 2, 2008 | 08:07 PM
69Vett's Avatar
69Vett
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
I would never trust any plastic line, they are too easy to cut or nick.
run 1/8"stainless hardline once and be done. 69VETT
Old Nov 2, 2008 | 08:12 PM
TimAT's Avatar
TimAT
The nylon line is pretty tough. The problem with a copper tube is the vibration (pulsing) of the oil pump will work-harden the line and it'll crack. If you do go with a hard line of some type, be sure and make some coils in the line for vibration damping.
Old Nov 3, 2008 | 04:58 PM
Young69Owner's Avatar
Young69Owner
My gauge line broke and I lost an engine
Anyways, buy the kit and you'll be all set.
DC
Old Nov 3, 2008 | 05:47 PM
blckslvr79's Avatar
blckslvr79
I had a plastic line break in my 74 Z28. Pumped about 2 quarts of dirty oil into my dash, radio, console, and carpet before I realized it.
Replaced it with hard line-no more issues.
My only luck was the interior was already black!
Old Nov 3, 2008 | 07:50 PM
Edzred72's Avatar
Edzred72
Crows foot on the end of your socket extension will snug that right up...
Eddie
To Does your's do this??
Old Nov 3, 2008 | 09:52 PM
dstaley's Avatar
dstaley
I use AN -4 from the engine up to a bulkhead fitting on my firewall. Inside the car I either use more AN line or 1/8" copper tubing, depending on whether or not I expect to have to disturb the line regularly or not.
Old Nov 3, 2008 | 11:48 PM
hammadown's Avatar
hammadown
Eddie
Thanks for the tip
Hammadown
Old Nov 4, 2008 | 12:04 AM
sly vette's Avatar
sly vette
I'm glad I went with new Autometer guages. All electric and no worries.
Sly
