Bellhouse vs Flywheel
Old Nov 9, 2008 | 02:54 PM
cajos's Avatar
cajos
Default Bellhouse vs Flywheel
Hi,
I have got a TKO600 in the workshop and soon I start installing it. Now our friends from Keisler want you to dialing in the Bellhouse. That' s ok. BUT should the flywheel not be dialed into see if it is flush to the crank. What if there is a "wobble". Or is this only my mind striving to perfection?
Old Nov 9, 2008 | 04:48 PM
TimAT's Avatar
TimAT
To me, that's just another part of being sure it's right. I would do a runout on the surface of the flywheel just to be sure it's flat. And then checking the runout and making sure the bellhousing is centered.
Old Nov 10, 2008 | 02:47 AM
cajos's Avatar
cajos
Any description of how to do that?
Old Nov 10, 2008 | 04:34 AM
HamadUP's Avatar
HamadUP
St. Jude Donor '08
You should use the clutch alignment tool for that, just like that picture :
Old Nov 10, 2008 | 04:39 AM
cajos's Avatar
cajos
Hmmm, that centers the clutch. I don't thing you can discover a outrun on the fly wheel with that.
Old Nov 10, 2008 | 11:44 AM
Gordonm's Avatar
Gordonm
Mount your base of the indicator on the block and then just move the arm so the indicator tip rides on the flywheel. That is easier then indicating the runout to the bellhousing. I would indicate the crank flange first and then do the flywheel. If out it could be the crank flange or the flywheel.
The clutch alignment tool won't indicate anything. Just makes the disc centered.
Old Nov 10, 2008 | 11:56 AM
Bob Onit's Avatar
Bob Onit
I wouldn't, that could get real expensive
Old Nov 10, 2008 | 12:47 PM
gkull's Avatar
gkull
Originally Posted by cajos
Hi,
The end of the crank is machined and flywheel is machined. I've never checked it. centering the bell housing is critical because it ensures that the tranny input shaft is centered in the crank bearing.
Old Nov 10, 2008 | 12:50 PM
cajos's Avatar
cajos
True, but you forget one thing, that's the idiot in the middle that has to install two perfectly machined pars, ME. I can screw up boiling water ;-).
Old Nov 10, 2008 | 12:56 PM
gkull's Avatar
gkull
Just bolt the flywheel to crank and TQ the bolts down. I never have given it a thought as to whether it was perfect 90 degree to the centerline of the crank.
Old Nov 10, 2008 | 04:14 PM
HamadUP's Avatar
HamadUP
St. Jude Donor '08
Oh, I thought your question was about centering the clutch.
Old Nov 10, 2008 | 06:41 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
I agree I have never checked this, and I check everything
Old Nov 10, 2008 | 08:17 PM
...Roger...'s Avatar
...Roger...
It "WILL" get you one of these days and it only takes a few min.
I found a Scat crank out .0005 on the flange surface.
I had a local engine builder return an engine to me with the flange out .004......flywheel was crazy out when bolted up.
I have seen a bunch of pilot bushing holes that were several thousands out from center and some of them only .550 deep.That really screws up an input shaft in short order.
I gave up assuming these things are OK since I'm the one that has to take them back out...FOR FREE.
You think a machine shop would check the flange surface but most of them cant even find the tolerance for the flange surface.
To Bellhouse vs Flywheel
