Battery Keeps Going Down
Old Nov 13, 2008 | 03:09 PM
...Roger...'s Avatar
...Roger...
Originally Posted by roger3
All of my readings were taken with the ignition key off.
Hmmm I'm not sure at this point why you would have a reading of .18v from the block to the wiper case.There has to be voltage present to go to ground through the meter to get a reading.Not sure what has voltage the block or the wiper case.Is this with the courtesy light fuse in or out?
(The courtesy light timer is part of a delay light system like a later model car.)
Old Nov 13, 2008 | 03:11 PM
roger3's Avatar
roger3
Let me throw in one more thing. The car has been sitting up about a year while I did some work to it (repaint it, remove interior to replace carpet, replace dash, replace stereo with simple aftermarket, fix clock, fix tack, fix speedo, replace courtesy light door swithces, replace door ajar switches, install new a/c controls, etc). While doing this work I noticed that one of the wires for the plug to the steering column was not installed in the plug. I put it back in the plug. I don't remember the color of the wire, but I thought it was odd that the colors on one side of the plug don't all match the colors on the other side of the plug. How can I tell if the steering column is the correct one for the car?
Prior to this work the battery did not drain down.
Old Nov 13, 2008 | 03:13 PM
roger3's Avatar
roger3
The fuse for the courtesy lights was in when I took the voltage readings on the wiper motor housing.
Old Nov 13, 2008 | 03:17 PM
...Roger...
"One" more thing??? Darn
Before going after your clock just try disconnecting the the harmonica connector at the column and see if the draw goes away.One of the wires going into the column makes the key buzzer work off the courtesy lights that could be the problem.
Old Nov 14, 2008 | 08:14 AM
roger3's Avatar
roger3
We have a winner!
Courtesy light in the Center Storage Compartment was on, the door wasn't closing all the way because it was hitting a screw head.
Closed it all the way and amperage went to 0, or at least too low for my multimeter to give a reading as the clock was still working.
Thanks to everyone for the help. Withouth your help I would have been chasing this problem for a while.
Old Nov 14, 2008 | 08:28 AM
1nicecorvette's Avatar
1nicecorvette
woo! i actually got one right for once! AHHHHH, this day will go down in history! thank you, thank you all! you like me, you really like me....
Old Nov 14, 2008 | 08:36 AM
Durango_Boy's Avatar
Durango_Boy
Good work.
