Some BB questions
Old Jan 13, 2002 | 10:40 PM
stickben's Avatar
stickben
Default Some BB questions
I may have a chance to aquire a 454 BB somtime in the not too distant future :D . I have a few questions. The engine is out of a 1979 chevy chyenne truck. Is there any design differences in the 454 from a truck vs a 454 from a corvette? What kind of modifications would I have to make to fit it into my car? I know its in good running order right now, but im assuming i might want to rebuild the engine, what should be done to it?
Thanks very much,
ben :D :D :D
Old Jan 13, 2002 | 10:49 PM
Aaron-74's Avatar
Aaron-74
Default Re: Some BB questions (stickben)
I really don't think there is anything that needs to be done to swap a BB in (talking about motor mounts) But that's what I think. I'm not real sure.
But, for the rebuild, it would be wise to replace all the bearings and oil pump. Get a nice hyd. cam. Get the heads ported/polishes with a 3 angle valve job topped off with 1.7:1 roller tip rockers. Edelbrock Performer RPM Air-Gap intake with a nice Holley 750 carb. Ceramic coated headers. Flow-Master mufflers. MSD dist/6AL/BlasterSS. Check the conidition of the piston rings and cylinder bores. Other then that, just plain BOIL some BFG's. :cheers:
[Modified by Aaron-74, 8:50 PM 1/13/2002]
Old Jan 13, 2002 | 11:01 PM
zwede's Avatar
zwede
Heads may be 'peanut port' style, and worthless for performance. Peanut ports are much smaller than oval ports.
The accessories will not work if it uses a long water pump. You will have to get Corvette brackets.
Truck intake will probably be too tall for your hood.
Old Jan 13, 2002 | 11:45 PM
bence13_33's Avatar
bence13_33
There really aren't too many differences. As some people have already pointed out the heads do have the "peanut" ports which are quite a bit smaller than the regular oval ports. You will probably want to scrap these heads because there really isn't much performance to be had. The pulleys, brackets and water pump are most likely for a long style water pump. If this is the case, they will be of no use to you because you will need to use a short style water pump. If you are going for a slight performance rebuild, the pistons are probably no good to you. They are most likely dished pistons yielding around 8.5:1 compression ratio.
Truck engines are usually run pretty hard, so there is probably a significant ridge on the cylinder walls. You will either need to use the ridge reemer or have it bored out. Hope I helped. :cheers:
Old Jan 13, 2002 | 11:47 PM
73 LS-4's Avatar
73 LS-4
Well there's tall deck blocks and short deck blocks with BB's, you can check this with the casting number on the block, your looking for a short deck. I think most of the light duty trucks had the short deks and only the heavy duty models had the taller decks but I could be wrong. As Zwede said, the trucks normally have the small peanut ports, which are pretty useless in a performance application, so new heads and intake would be in order (and the other why I'm in there's) unless they were changed sometime in the past.
:cheers:
Pat Kunz
Old Jan 14, 2002 | 12:29 AM
bence13_33's Avatar
bence13_33
Default Re: Some BB questions (73 LS-4)
73 LS-4:
Actually you really only need to worry about a tall deck with the 427s. There are very few production tall deck 454s....I believe they were made after 1990. Mortec shows three tall deck 454s. The only way to be sure is to check the casting numbers.
Old Jan 14, 2002 | 01:12 AM
73 LS-4's Avatar
73 LS-4
Default Re: Some BB questions (bence13_33)
73 LS-4:
You're right, sorry I had a brain fart :crazy:
:cheers:
Pat Kunz
Old Jan 14, 2002 | 02:13 PM
stickben's Avatar
stickben
ahh, ok if it has the peanut ports then changing the heads will be out of my price range. ok, ill check the casting numbers sometime and post them.
To Some BB questions
